Activity › Forums › Maxon Cinema 4D › coordinates missing for points on spline
  • coordinates missing for points on spline
    Posted by Steve Bentley on June 30, 2019 at 4:26 am
    Hey all,
    I must have missed the memo. When did we loose coordinates for points on a spline? (in the coordinates window).
    If you select and then move a point around, the coordinates window lets you know how much you have moved it by, but when you let go, the numbers reset to zero. This happens whether you are on world or relative or absolute.
    As far as I can tell, there is no way to know where a point on a spline is in space. (except for the structure manager of course – but that gets messy)
    This wasn’t the case in R18, and I don’t remember it being in R19 (where I am now). Has this suddenly just happened?
    Steve Bentley replied 7 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    June 30, 2019 at 4:58 am
    19 and 20 are behaving as expected here, coordinate manager just reports position not delta then return to 0.
  • Steve Bentley
    June 30, 2019 at 5:01 am
    Thanks Brian,
    Time to throw the prefs out I guess.
