Cookie cutter, my own masks?
Posted by Sandwich on December 17, 2005 at 10:20 pmJust curious if there is any way to create your own masks (shapes) for Cookie Cutter.
Thanks in advance.
Arthur Bueno replied 20 years, 8 months ago 3 Members · 4 Replies -
Edward Troxel
December 18, 2005 at 4:08 am -
Sandwich
December 18, 2005 at 10:55 amI see.
I got Vegas Video 5.0 by the way, but I cant find it in the video FX.
Is it somewhere else or is it simply not included in my version? :/ -
Edward Troxel
December 18, 2005 at 12:46 pmIt’s included, you just have to MANUALLY create it. Try this:
Put the standard “Linear White to Black” generated media on track 1. This is where you would eventually substitute your own gradient black and white image.
To this generated media, add a Sony Mask Generator effect.
On Track 1, change the Compositing Mode to Multiply (Mask)
On Track 2, place the one of your video clips and then change track 2 to be a CHILD of track 1.
On Track 3, place the other video clip.
Now you can adjust the sliders in the Mask Generator effect on the gradient so as much or as little of Track 2 appears. Using this method, you can provide your own gradients and use them similarly to the results you get with the Cookie Cutter effect.
Arthur Bueno
December 18, 2005 at 5:07 pmI think the easiest way to create a cookie cutter with your own shape is:
-open the event pan/crop window
-activate the Mask checkbox in the lower left corner
-choose the anchor creation tool and draw the shape.
-you can invert the mask by selecting Mode: Negative (in the Path menu)
