Activity Forums VEGAS Pro cookie cutter aspect ratio?
  • cookie cutter aspect ratio?
    Posted by Brad Leigh on August 27, 2013 at 5:52 pm
    Cookie cutter is almost perfect for my needs, I am using it in alpha mode to let a lower track image come through a SMALL area of the upper image that uses alpha channel. I am already using pan crop both layers. ( I have many video layers at this point) that only problem I have in cookie cutter is I don’t see a way to adjust the aspect ratio of the rectangle. I would like it more oblong.
    Can I do this or is there another plug in that will do this? Using the alpha mask seemed to not work because it appeared to follow the existing pan crop of the track.
    Thanks Brad.
    Sent from smartphone hope no crazy spell check substitutions
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
    Brad Leigh replied 13 years ago 2 Members · 4 Replies
  • Graham Bernard
    August 27, 2013 at 9:25 pm
    Sounds like a job for The Mask“! – It’s in PanCrop. You could make any size of oblong you want.
    Cheers
    Grazie
  • Brad Leigh
    August 27, 2013 at 10:04 pm
    Thanks. Problem is I’m already using pan crop on this layer and I don’t want the alpha mask that size.
    B
  • Graham Bernard
    August 28, 2013 at 4:51 am
    [Brad Leigh] “Problem is I’m already using pan crop on this layer and I don’t want the alpha mask that size”
    _______________________________________________________________
    I’d need to see your “layout” to get an understanding of where you’re at with this. I could keep on suggesting more and more options and be well off target.
    Cheers
    Grazie
  • Brad Leigh
    August 28, 2013 at 11:24 pm
    Grazie
    If the cookie cutter had control of width and height when set to alpha
    it would be perfect. Pan Crop is already in use in this layer and seems to be tied to the alpha mask so I can’t use the Alpha Mask.
    I figured out if I render my animations in more layers I don’t need the cookie cutter. Was just trying to save the extra work.
    Brad
