Activity Forums Letters to the COW Team Converting YUV data to AVFrame
  • Converting YUV data to AVFrame
    Posted by Gaurav Pathak on April 28, 2015 at 6:04 am
    Hello all,
    I am working on encoding a raw yuv stream coming directly from webcam, using v4l2. The issue that I am facing is that even after using avpicture_fill and assigning every buffer separately
    frame->data[0] = buffers[buf.index].start;
    frame->data[1] = (buffers[buf.index].start)+1;
    frame->data[2] = (buffers[buf.index].start)+3;
    The output is not getting encoded and I am getting raw video.
    My Code is:
    #include "math.h"
    #include "libavutil/opt.h"
    #include "libavcodec/avcodec.h"
    #include "libavutil/channel_layout.h"
    #include "libavutil/common.h"
    #include "libavutil/imgutils.h"
    #include "libavutil/mathematics.h"
    #include "libavutil/samplefmt.h"
    #include "stdio.h"
    #include "stdlib.h"
    #include "string.h"
    #include "assert.h"
    #include "getopt.h"
    #include "fcntl.h"
    #include "unistd.h"
    #include "errno.h"
    #include "malloc.h"
    #include "sys/stat.h"
    #include "sys/types.h"
    #include "sys/time.h"
    #include "sys/mman.h"
    #include "sys/ioctl.h"
    #include "asm/types.h"
    #include "linux/videodev2.h"
    #define INBUF_SIZE 4096
    #define AUDIO_INBUF_SIZE 20480
    #define AUDIO_REFILL_THRESH 4096
    #define CLEAR(x) memset (&(x), 0, sizeof (x))
    unsigned char *outbuffer = NULL;
    unsigned long buff_siz = 0;
    char out_name[256];
    typedef enum
    #ifdef IO_READ
    IO_METHOD_READ,
    #endif
    #ifdef IO_MMAP
    IO_METHOD_MMAP,
    #endif
    #ifdef IO_USERPTR
    IO_METHOD_USERPTR,
    #endif
    }io_method;
    struct buffer
    void *start;
    size_t length;
    static io_method io = IO_METHOD_MMAP;
    static int fd = -1;
    struct buffer * buffers = NULL;
    static unsigned int n_buffers = 0;
    // global settings
    static unsigned int width = 640;
    static unsigned int height = 480;
    static unsigned char jpegQuality = 70;
    //static char* jpegFilename = NULL;
    static char* deviceName = "/dev/video0";
    AVCodec *codec;
    AVCodecContext *c= NULL;
    int i, ret, x, y, got_output;
    FILE *fout;
    AVFrame *frame;
    AVPacket pkt;
    uint8_t endcode[] = { 0, 0, 1, 0xb7 };
    static int num=0;
    Convert from YUV422 format to RGB888. Formulae are described on https://en.wikipedia.org/wiki/YUV
    \param width width of image
    \param height height of image
    \param src source
    \param dst destination
    static void YUV422toRGB888(int width, int height, unsigned char *src, unsigned char *dst)
    int line, column;
    unsigned char *py, *pu, *pv;
    unsigned char *tmp = dst;
    /* In this format each four bytes is two pixels. Each four bytes is two Y's, a Cb and a Cr.
    Each Y goes to one of the pixels, and the Cb and Cr belong to both pixels. */
    py = src;
    pu = src + 1;
    pv = src + 3;
    #define CLIP(x) ( (x)>=0xFF ? 0xFF : ( (x) <= 0x00 ? 0x00 : (x) ) )
    for (line = 0; line < height; ++line) {
    for (column = 0; column < width; ++column) {
    *tmp++ = CLIP((double)*py + 1.402*((double)*pv-128.0));
    *tmp++ = CLIP((double)*py - 0.344*((double)*pu-128.0) - 0.714*((double)*pv-128.0));
    *tmp++ = CLIP((double)*py + 1.772*((double)*pu-128.0));
    // increase py every time
    py += 2;
    // increase pu,pv every second time
    if ((column & 1)==1) {
    pu += 4;
    pv += 4;
    Print error message and terminate programm with EXIT_FAILURE return code.
    \param s error message to print
    static void errno_exit(const char* s)
    fprintf(stderr, "%s error %d, %s\n", s, errno, strerror (errno));
    exit(EXIT_FAILURE);
    Do ioctl and retry if error was EINTR ("A signal was caught during the ioctl() operation."). Parameters are the same as on ioctl.
    \param fd file descriptor
    \param request request
    \param argp argument
    \returns result from ioctl
    static int xioctl(int fd, int request, void* argp)
    int r;
    do r = ioctl(fd, request, argp);
    while (-1 == r && EINTR == errno);
    return r;
    process image read
    static void imageProcess(const void* p)
    unsigned char* src = (unsigned char*)p;
    unsigned char* dst = malloc(width*height*3*sizeof(char));
    // convert from YUV422 to RGB888
    YUV422toRGB888(width,height,src,dst);
    void print_array(int *ptr,int len)
    // while(len-- > 0)
    printf("YUV Data is %x\n",*ptr);
    ptr++;
    read single frame
    static int frameRead(void)
    struct v4l2_buffer buf;
    #ifdef IO_USERPTR
    unsigned int i;
    #endif
    switch (io)
    #ifdef IO_READ
    case IO_METHOD_READ:
    if (-1 == read (fd, buffers[0].start, buffers[0].length))
    switch (errno)
    case EAGAIN:
    return 0;
    case EIO:
    // Could ignore EIO, see spec.
    // fall through
    default:
    errno_exit("read");
    imageProcess(buffers[0].start);
    break;
    #endif
    #ifdef IO_MMAP
    case IO_METHOD_MMAP:
    CLEAR (buf);
    buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    buf.memory = V4L2_MEMORY_MMAP;
    if (-1 == xioctl(fd, VIDIOC_DQBUF, &buf))
    switch (errno)
    case EAGAIN:
    return 0;
    case EIO:
    // fall through
    default:
    errno_exit("VIDIOC_DQBUF");
    assert (buf.index < n_buffers);
    if (-1 == xioctl(fd, VIDIOC_QBUF, &buf))
    errno_exit("VIDIOC_QBUF");
    av_init_packet(&pkt);
    pkt.data = NULL; // packet data will be allocated by the encoder
    pkt.size = 0;
    fflush(stdout);
    avpicture_fill((AVPicture*)frame, NULL, frame->format, frame->width, frame->height);
    // print_array(buffers[buf.index].start,buffers[buf.index].length);
    frame->pts = num;
    num++;
    /* encode the image */
    ret = avcodec_encode_video2(c, &pkt, frame, &got_output);
    if (ret < 0)
    fprintf(stderr, "Error encoding frame\n");
    exit(1);
    if (got_output)
    // printf("Write frame %3d (size=%5d)\n", num, pkt.size);
    fwrite(pkt.data, 1, pkt.size, fout);
    av_free_packet(&pkt);
    break;
    #endif
    #ifdef IO_USERPTR
    case IO_METHOD_USERPTR:
    CLEAR (buf);
    buf.memory = V4L2_MEMORY_USERPTR;
    if (-1 == xioctl(fd, VIDIOC_DQBUF, &buf)) {
    switch (errno) {
    case EAGAIN:
    return 0;
    case EIO:
    // fall through
    default:
    for (i = 0; i < n_buffers; ++i)
    if (buf.m.userptr == (unsigned long) buffers[i].start && buf.length == buffers[i].length)
    break;
    assert (i < n_buffers);
    imageProcess((void *) buf.m.userptr);
    break;
    #endif
    return 1;
    mainloop: read frames and process them
    static void mainLoop(void)
    unsigned int count,codec_id=AV_CODEC_ID_H264;
    char *filename="abc.flv";
    count = 300;
    avcodec_register_all();
    printf("Encode video file %s\n", filename);
    /* find the mpeg1 video encoder */
    codec = avcodec_find_encoder(codec_id);
    if (!codec)
    fprintf(stderr, "Codec not found\n");
    exit(1);
    c = avcodec_alloc_context3(codec);
    if (!c)
    fprintf(stderr, "Could not allocate video codec context\n");
    exit(1);
    /* put sample parameters */
    c->bit_rate = 10000000;
    /* resolution must be a multiple of two */
    c->width = 640;
    c->height = 480;
    /* frames per second */
    c->time_base = (AVRational){1,25};
    c->gop_size = 10; /* emit one intra frame every ten frames */
    c->max_b_frames = 1;
    c->pix_fmt = AV_PIX_FMT_YUV420P;
    if (codec_id == AV_CODEC_ID_H264)
    av_opt_set(c->priv_data, "preset", "ultrafast", 0);
    /* open it */
    if (avcodec_open2(c, codec, NULL) < 0)
    fprintf(stderr, "Could not open codec\n");
    exit(1);
    fout = fopen(filename, "wb");
    if (!fout)
    fprintf(stderr, "Could not open %s\n", filename);
    exit(1);
    frame = av_frame_alloc();
    if (!frame)
    fprintf(stderr, "Could not allocate video frame\n");
    exit(1);
    frame->format = c->pix_fmt;
    frame->width = c->width;
    frame->height = c->height;
    /* the image can be allocated by any means and av_image_alloc() is
    * just the most convenient way if av_malloc() is to be used */
    // ret = av_image_alloc(frame->data, frame->linesize, c->width, c->height,c->pix_fmt, 32);
    // if (ret < 0)
    // fprintf(stderr, "Could not allocate raw picture buffer\n");
    // exit(1);
    while (count-- > 0)
    for (;;)
    fd_set fds;
    struct timeval tv;
    int r;
    FD_ZERO(&fds);
    FD_SET(fd, &fds);
    /* Timeout. */
    tv.tv_sec = 10;
    tv.tv_usec = 0;
    r = select(fd + 1, &fds, NULL, NULL, &tv);
    if (-1 == r) {
    if (EINTR == errno)
    continue;
    errno_exit("select");
    if (0 == r) {
    fprintf (stderr, "select timeout\n");
    exit(EXIT_FAILURE);
    if (frameRead())
    break;
    /* EAGAIN - continue select loop. */
    for (got_output = 1; got_output; num++)
    fflush(stdout);
    ret = avcodec_encode_video2(c, &pkt, NULL, &got_output);
    if (ret < 0)
    exit(1);
    if (got_output)
    /* add sequence end code to have a real mpeg file */
    fwrite(endcode, 1, sizeof(endcode), fout);
    fclose(fout);
    avcodec_close(c);
    av_free(c);
    // av_freep(&frame->data[0]);
    av_frame_free(&frame);
    printf("\n");
    stop capturing
    static void captureStop(void)
    enum v4l2_buf_type type;
    switch (io)
    #ifdef IO_READ
    /* Nothing to do. */
    break;
    #endif
    #ifdef IO_MMAP
    #endif
    #ifdef IO_USERPTR
    #endif
    #if defined(IO_MMAP) || defined(IO_USERPTR)
    if (-1 == xioctl(fd, VIDIOC_STREAMOFF, &type))
    errno_exit("VIDIOC_STREAMOFF");
    break;
    #endif
    start capturing
    static void captureStart(void)
    unsigned int i;
    switch (io) {
    #ifdef IO_READ
    break;
    #endif
    #ifdef IO_MMAP
    CLEAR (buf);
    buf.index = i;
    if (-1 == xioctl(fd, VIDIOC_STREAMON, &type))
    errno_exit("VIDIOC_STREAMON");
    break;
    #endif
    #ifdef IO_USERPTR
    for (i = 0; i < n_buffers; ++i) {
    CLEAR (buf);
    buf.index = i;
    buf.m.userptr = (unsigned long) buffers[i].start;
    buf.length = buffers[i].length;
    break;
    #endif
    static void deviceUninit(void)
    unsigned int i;
    switch (io) {
    #ifdef IO_READ
    free(buffers[0].start);
    break;
    #endif
    #ifdef IO_MMAP
    if (-1 == munmap (buffers[i].start, buffers[i].length))
    errno_exit("munmap");
    break;
    #endif
    #ifdef IO_USERPTR
    free (buffers[i].start);
    break;
    #endif
    free(buffers);
    #ifdef IO_READ
    static void readInit(unsigned int buffer_size)
    buffers = calloc(1, sizeof(*buffers));
    if (!buffers) {
    fprintf (stderr, "Out of memory\n");
    exit(EXIT_FAILURE);
    buffers[0].length = buffer_size;
    buffers[0].start = malloc (buffer_size);
    if (!buffers[0].start) {
    exit(EXIT_FAILURE);
    #endif
    #ifdef IO_MMAP
    static void mmapInit(void)
    struct v4l2_requestbuffers req;
    CLEAR (req);
    req.count = 4;
    req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    req.memory = V4L2_MEMORY_MMAP;
    if (-1 == xioctl(fd, VIDIOC_REQBUFS, &req)) {
    if (EINVAL == errno) {
    fprintf(stderr, "%s does not support memory mapping\n", deviceName);
    exit(EXIT_FAILURE);
    } else {
    errno_exit("VIDIOC_REQBUFS");
    if (req.count < 2) {
    fprintf(stderr, "Insufficient buffer memory on %s\n", deviceName);
    exit(EXIT_FAILURE);
    buffers = calloc(req.count, sizeof(*buffers));
    if (!buffers) {
    fprintf(stderr, "Out of memory\n");
    exit(EXIT_FAILURE);
    for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
    CLEAR (buf);
    buf.index = n_buffers;
    if (-1 == xioctl(fd, VIDIOC_QUERYBUF, &buf))
    errno_exit("VIDIOC_QUERYBUF");
    buffers[n_buffers].length = buf.length;
    buffers[n_buffers].start =
    mmap (NULL /* start anywhere */, buf.length, PROT_READ | PROT_WRITE /* required */, MAP_SHARED /* recommended */, fd, buf.m.offset);
    if (MAP_FAILED == buffers[n_buffers].start)
    errno_exit("mmap");
    #endif
    #ifdef IO_USERPTR
    static void userptrInit(unsigned int buffer_size)
    unsigned int page_size;
    page_size = getpagesize ();
    buffer_size = (buffer_size + page_size - 1) & ~(page_size - 1);
    CLEAR(req);
    req.count = 4;
    req.memory = V4L2_MEMORY_USERPTR;
    fprintf(stderr, "%s does not support user pointer i/o\n", deviceName);
    exit(EXIT_FAILURE);
    } else {
    buffers = calloc(4, sizeof (*buffers));
    if (!buffers) {
    exit(EXIT_FAILURE);
    for (n_buffers = 0; n_buffers < 4; ++n_buffers) {
    buffers[n_buffers].length = buffer_size;
    buffers[n_buffers].start = memalign (/* boundary */ page_size, buffer_size);
    if (!buffers[n_buffers].start) {
    exit(EXIT_FAILURE);
    #endif
    initialize device
    static void deviceInit(void)
    struct v4l2_streamparm stream;
    struct v4l2_capability cap;
    struct v4l2_cropcap cropcap;
    struct v4l2_crop crop;
    struct v4l2_format fmt;
    unsigned int min;
    if (-1 == xioctl(fd, VIDIOC_QUERYCAP, &cap))
    fprintf(stderr, "%s is no V4L2 device\n",deviceName);
    exit(EXIT_FAILURE);
    else
    errno_exit("VIDIOC_QUERYCAP");
    if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE))
    fprintf(stderr, "%s is no video capture device\n",deviceName);
    exit(EXIT_FAILURE);
    if (-1 == xioctl(fd, VIDIOC_G_PARM, &stream))
    // if (EINVAL == errno)
    // fprintf(stderr, "%s is no V4L2 device\n",deviceName);
    // exit(EXIT_FAILURE);
    // else
    // errno_exit("VIDIOC_QUERYCAP");
    printf("Stream Paramater Type %u\n",stream.type);
    printf("Input numerator %d\n",stream.parm.capture.timeperframe.numerator);
    printf("Input denominator %d\n",stream.parm.capture.timeperframe.denominator);
    printf("output numerator %d\n",stream.parm.output.timeperframe.numerator);
    printf("output denominator %d\n",stream.parm.output.timeperframe.denominator);
    switch (io) {
    #ifdef IO_READ
    if (!(cap.capabilities & V4L2_CAP_READWRITE)) {
    fprintf(stderr, "%s does not support read i/o\n",deviceName);
    exit(EXIT_FAILURE);
    break;
    #endif
    #ifdef IO_MMAP
    #endif
    #ifdef IO_USERPTR
    #endif
    if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
    fprintf(stderr, "%s does not support streaming i/o\n",deviceName);
    exit(EXIT_FAILURE);
    break;
    #endif
    /* Select video input, video standard and tune here. */
    CLEAR(cropcap);
    cropcap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    if (0 == xioctl(fd, VIDIOC_CROPCAP, &cropcap))
    crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    crop.c = cropcap.defrect; /* reset to default */
    if (-1 == xioctl(fd, VIDIOC_S_CROP, &crop)) {
    switch (errno) {
    case EINVAL:
    /* Cropping not supported. */
    break;
    default:
    /* Errors ignored. */
    break;
    } else {
    CLEAR (fmt);
    // v4l2_format
    fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
    fmt.fmt.pix.width = width;
    fmt.fmt.pix.height = height;
    fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_YVU420;
    fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
    if (-1 == xioctl(fd, VIDIOC_S_FMT, &fmt))
    errno_exit("VIDIOC_S_FMT");
    /* Note VIDIOC_S_FMT may change width and height. */
    if (width != fmt.fmt.pix.width)
    width = fmt.fmt.pix.width;
    fprintf(stderr,"Image width set to %i by device %s.\n",width,deviceName);
    if (height != fmt.fmt.pix.height)
    height = fmt.fmt.pix.height;
    fprintf(stderr,"Image height set to %i by device %s.\n",height,deviceName);
    /* Buggy driver paranoia. */
    min = fmt.fmt.pix.width * 2;
    if (fmt.fmt.pix.bytesperline < min)
    fmt.fmt.pix.bytesperline = min;
    min = fmt.fmt.pix.bytesperline * fmt.fmt.pix.height;
    if (fmt.fmt.pix.sizeimage < min)
    fmt.fmt.pix.sizeimage = min;
    switch (io)
    #ifdef IO_READ
    readInit(fmt.fmt.pix.sizeimage);
    break;
    #endif
    #ifdef IO_MMAP
    mmapInit();
    break;
    #endif
    #ifdef IO_USERPTR
    userptrInit(fmt.fmt.pix.sizeimage);
    break;
    #endif
    close device
    static void deviceClose(void)
    if (-1 == close (fd))
    errno_exit("close");
    fd = -1;
    open device
    static void deviceOpen(void)
    struct stat st;
    // stat file
    if (-1 == stat(deviceName, &st))
    fprintf(stderr, "Cannot identify '%s': %d, %s\n", deviceName, errno, strerror (errno));
    exit(EXIT_FAILURE);
    // check if its device
    if (!S_ISCHR (st.st_mode))
    fprintf(stderr, "%s is no device\n", deviceName);
    exit(EXIT_FAILURE);
    // open device
    fd = open(deviceName, O_RDWR /* required */ | O_NONBLOCK, 0);
    // check if opening was successfull
    if (-1 == fd) {
    fprintf(stderr, "Cannot open '%s': %d, %s\n", deviceName, errno, strerror (errno));
    exit(EXIT_FAILURE);
    print usage information
    static void usage(FILE* fp, int argc, char** argv)
    fprintf (fp,
    "Usage: %s [options]\n\n"
    "Options:\n"
    "-d | --device name Video device name [/dev/video0]\n"
    "-h | --help Print this message\n"
    "-o | --output JPEG output filename\n"
    "-q | --quality JPEG quality (0-100)\n"
    "-m | --mmap Use memory mapped buffers\n"
    "-r | --read Use read() calls\n"
    "-u | --userptr Use application allocated buffers\n"
    "-W | --width width\n"
    "-H | --height height\n"
    argv[0]);
    static const char short_options [] = "d:ho:q:mruW:H:";
    static const struct option
    long_options [] = {
    { "device", required_argument, NULL, 'd' },
    { "help", no_argument, NULL, 'h' },
    { "output", required_argument, NULL, 'o' },
    { "quality", required_argument, NULL, 'q' },
    { "mmap", no_argument, NULL, 'm' },
    { "read", no_argument, NULL, 'r' },
    { "userptr", no_argument, NULL, 'u' },
    { "width", required_argument, NULL, 'W' },
    { "height", required_argument, NULL, 'H' },
    { 0, 0, 0, 0 }
    int main(int argc, char **argv)
    for (;;) {
    int index, c = 0;
    c = getopt_long(argc, argv, short_options, long_options, &index);
    if (-1 == c)
    break;
    switch (c)
    case 0: /* getopt_long() flag */
    break;
    case 'd':
    deviceName = optarg;
    break;
    case 'h':
    // print help
    usage (stdout, argc, argv);
    exit(EXIT_SUCCESS);
    case 'q':
    // set jpeg filename
    jpegQuality = atoi(optarg);
    break;
    case 'm':
    #ifdef IO_MMAP
    #else
    fprintf(stderr, "You didn't compile for mmap support.\n");
    exit(EXIT_FAILURE);
    #endif
    break;
    case 'r':
    #ifdef IO_READ
    io = IO_METHOD_READ;
    #else
    fprintf(stderr, "You didn't compile for read support.\n");
    exit(EXIT_FAILURE);
    #endif
    break;
    case 'u':
    #ifdef IO_USERPTR
    io = IO_METHOD_USERPTR;
    #else
    fprintf(stderr, "You didn't compile for userptr support.\n");
    exit(EXIT_FAILURE);
    #endif
    break;
    case 'W':
    // set width
    width = atoi(optarg);
    break;
    case 'H':
    // set height
    height = atoi(optarg);
    break;
    default:
    usage(stderr, argc, argv);
    exit(EXIT_FAILURE);
    // open and initialize device
    deviceOpen();
    deviceInit();
    // start capturing
    captureStart();
    // process frames
    mainLoop();
    // stop capturing
    captureStop();
    // close device
    deviceUninit();
    deviceClose();
    exit(EXIT_SUCCESS);
    return 0;
    It is just for testing, so there are various unused and irrelevant variables in this code.
    For Compiling I am running this command
    gcc encode.c -o encode -L/usr/local/lib -lavcodec -lavformat -lavutil -lavfilter -lavdevice -lm -lswscale -lswresample -lx264 -lpthread -lz -lfdk-aac -lvpx -lmp3lame -lopus -lvorbis -lvorbisenc -lvorbisfile -ldl -lva -llzma -ltheora -logg
    Gaurav Pathak replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
