Activity Forums Adobe Premiere Pro Converting xml audio files to avi audio for pp1.5
  • Converting xml audio files to avi audio for pp1.5
    Posted by Chibear58 on September 2, 2006 at 12:36 pm
    Hello I recived a audio file from a client(the radio mix mp3) via the net. in an E-mail.I exported the file from the E-mail.Into PP 1.5,but can’t use it because the is marked as a XML.How can I convert this file to a AVI.To insert onto my new audio timeline for the second radio edit.
    Thanks for your Help
    Ben Wilson replied 19 years, 12 months ago 2 Members · 1 Reply
  • Ben Wilson
    September 7, 2006 at 5:41 pm
    Hmmmm,
    I may be behind the times, but the only XML I know is the extensible Markup language. This is a text based data format, not an audio format. I found this in an article on NetworkWorld.com
    The World Wide Web Consortium, the group overseeing the XML standard, defines the language best: XML is a set of rules for designing text formats that lets you structure your data.
    << Are you sure you got the right file? or were sent the right thing? Ben Wilson Engineering Project Manager SCETV
