Activity › Forums › Apple Final Cut Pro Legacy › converting video to FLV via FCP 7
Carolyn Lecorre replied 16 years, 4 months ago 13 Members · 15 Replies
Christopher Targia
September 25, 2009 at 3:01 pmso is what your saying that you can/should, export as a quicktime movie, with H2.64 compression, then just rename the file extension to .flv?!? that seems error prone, does that really work, or am I misunderstanding the process?
Imre Szekely
January 26, 2010 at 3:11 pmThe option to export as FLV from FCP comes only if you installed Adobe Flash CS3. Flash CS3 had the option to install the FLV conversion component to Final Cut.
The CS4 package has NO more this feature… not sure why.I just recently updated my CS4 softwares to the latest update…and now when I export my timeline to quicktime and I use Adobe Media Encoder CS4 to create an FLV…..the end result is a greyed out and washed out video. Not sure why as in the preview it shows all good.
…problems…
Marni Page
March 25, 2010 at 12:05 amI have used the renaming trick with lots of success for movies that I have created as H264 with AAC audio.
Now I’ve exported an h264 .mov with 32-bit Floating Point Little Endian audio out of an Avid Express. I renamed the file as usual and the picture looks fine, but I get no audio when I play it back.
Does anyone have any idea why this would be? Are there specific audio formats that flvs like?
Tom Brooks
March 25, 2010 at 12:21 am[Marni Page] “Does anyone have any idea why this would be? Are there specific audio formats that flvs like?”
Very much so. This link gives a list if you can make heads or tails of it. But there is one choice that beats the others hands down and that’s AAC.
https://kb2.adobe.com/cps/402/kb402866.html
Carolyn Lecorre
May 18, 2010 at 11:16 pmNorman Bethune was a Canadian-born doctor and is a hero to Communist China. Sure, your name may be that of his, but I think you should quit posting your ad for your product as a solution you’ve discovered. All you’ve contributed is the same link to the same software site on all the threads to which you’ve “contributed”. Sketchy…
Check out: https://en.wikipedia.org/wiki/Norman_Bethune
