Activity Forums Sony Cameras converting to sd
  • converting to sd
    Posted by Deepak Verma on March 14, 2008 at 12:20 pm
    I am planning to buy and pmw-ex1. but at the moment struggling with a question
    the inherent format for the camera is 16:9 where as my requirement is SD for broadcast purpose in India and wide screen for other purpose
    i have read that it is possible to downcovert the footage in SD.
    as i have seen with some other downconversions that they keep the aspect ratio same – while coverting the footage. how is it possible to covert HD to SD so that it becomes real SD – mean i do want black bands above and below.
    has anybody done it that way?
    can they share a clip or two?
    will there be a quality loss?
    Ron Shook replied 18 years, 6 months ago 3 Members · 4 Replies
  • Kevin Jones
    March 14, 2008 at 7:54 pm
    The way I see it is you will either have letter boxed images-bands at top and bottom, or center punched- no bands at top or bottom, but the side are cropped.
    Center punching fills up an SD screen completely.
    If you shoot with center punching in mind it should not present a problem.
    You also have the option of panning around within the picture.
    Kevin Jones
    2.5GHz Quad-core PowerPC G5
    Final Cut Studio 2
  • Deepak Verma
    March 15, 2008 at 3:41 am
    thanks Kevin
    what will be the best format to shoot if i shoot keeping center punching in mind so that it comes automatically vertically and i crop sides (to the bare mi minimum possible)
    as the final output is going to be on DIGIbeta for telecast
    second will in involve redering in FCP – i have 5.1.4 and soon planning to migrate to studio 2
    what kind of losses i should keep in mind
  • Kevin Jones
    March 15, 2008 at 6:05 pm
    I have only been shooting in 1080 formats.
    The tricky part is setting up FCP.
    I’ve been editing in an EX-1 timeline using the Apple Pro Res Codec for rendering. Then copying everything and dropping onto a DV timeline for DVCAM recording.
    You will need FCP Studio 2 and all the upgrades. Quicktime etc.
    Kevin jones
    Final Cut Studio 2
  • Ron Shook
    March 16, 2008 at 6:19 am
    Kevin,
    [Kevin Jones] “I’ve been editing in an EX-1 timeline using the Apple Pro Res Codec for rendering. Then copying everything and dropping onto a DV timeline for DVCAM recording.”
    I don’t know FCP at all, but may need to interface with it sometime. Can I assume that Deepak should follow your methodology up to but not including dropping into a DV timeline and rather drop into a 601 uncompressed timeline, render and play out to his D-Beta deck?
    Ron Shook
    Shoulder-High Eye Productions
    CreativeCOW Forum Host for Discreet edit*
