Activity Forums Adobe After Effects Converting shape layer object to normal position
  • Converting shape layer object to normal position
    Posted by Jim Holden on March 7, 2017 at 1:01 am
    I’m trying to connect a certain shape part of a shape layer to the starting point property of the Beam effect. However, the shape layer object position keyframes are way off from where I want them to be when inputed into the the starting point variable.
    Greg Gesch replied 9 years, 6 months ago 2 Members · 1 Reply
  • Greg Gesch
    March 7, 2017 at 3:05 am
    Hi Jim, I’m presuming that your Beam length is set to 100%? In which case you probably need to use the Pan Behind tool to move the anchor point of the shape layer to where you want the shape to connect with the beam. Or that would be my guess?
