Activity Forums Apple Final Cut Pro Legacy converting QT DV movie to true 30fps and 48khz
  • converting QT DV movie to true 30fps and 48khz
    Posted by Wrongbeachph on September 25, 2007 at 2:30 am
    Im trying to take a QT and convert it to TRUE 30fps for our audio dept….how can I do this, Ive tried using compressor, or digitizing at 30 fps, and the QT says its playing at 29.97 even though it says it is a 30fps QT file……any ideas???
    Paul
    Jeremy Garchow replied 18 years, 11 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    September 25, 2007 at 9:25 am
    Why do you need true 30fps? Audio should be ale to work @ 29.97.
    Cinema tools will convert your movie to 30.0fps ‘losslessly’ if you really need it, but you shouldn’t.
  • Wrongbeachph
    September 25, 2007 at 7:14 pm
    Im not really sure, but our sound dept, using Pro Tools asked for 30fps not 29.97……dont ask me why…..we are all a bit confused by the request….but every time I use anything compressor or otherwise to convert the file, even though it says it is playing at 30fps, the files says it is 29.97 and when I send our sound dept the file they also say it is 29.97….any ideas???
  • Ronnyahmad
    September 27, 2007 at 2:48 am
    try to convert your file using mpeg stream clip, its free from
    https://www.squared5.com/
    regards,
    ronny
    brunei
  • Jeremy Garchow
    September 27, 2007 at 6:50 am
    Open the file in Cinema Tools, click conform and choose 30.0.
    Jeremy
