Activity › Forums › Apple Final Cut Pro Legacy › converting PowerPoint to QuickTime?
Posted by Michael Mcswain on February 28, 2007 at 4:33 pmanybody know the best way to get a PowerPoint Presentation into FCP?
Jeremy Garchow replied 19 years, 7 months ago 2 Members · 2 Replies -
Jeremy Garchow
February 28, 2007 at 4:50 pmExport it as a quicktime from PPT.
Open it keynote and export as quicktime.
the best way is to rent a scan converter, and record it to tape (or straight to FCP) and then capture that way. You can reformat as you need with the scan converter with the utmost quality and the transitions will play correctly (if you need those).
Jeremy
Jeremy Garchow
February 28, 2007 at 4:52 pmI forgot that you can also export the PPT as an image sequence as well.
Jeremy
