Activity › Forums › Adobe After Effects › CONVERTING PAL FCP Project to NTSC DVD?
  • CONVERTING PAL FCP Project to NTSC DVD?
    Posted by Michael Brown on June 18, 2012 at 10:55 am
    Hi folks,
    This has been answered in the past but lots has changed since then, so here I go again:
    I have an 18 min. short with only one cut in it, very little movement and only a few simple titles that I need to deliver a preview on NTSC DVD for a few festivals (there are still some that only take NTSC DVDs for preview, believe it or not). I shot on 1080p and made the Pal DVD by exporting it to ProRes 422 at 720×576 16:9 – no problem so far. The DVD SP 4 manual claims that DVDSP can encode Pal footage to NTSC if you import Pal to an NTSC DVDSP project (we’re talking SD of course). No dice, asset not accepted.
    I have tried to export the sequence from FCP7 to NTSC 720×480 16:9 @ 29,97 fps, but QT will not play it properly (the frame rate varies constantly during playback and the image has the typical jumps every second or so, so I’m aware that my footage has not really been transcoded).
    Do I need to send this to a lab that is properly equipped (which would barely be worth the trouble) or can I handle this myself?
    MacBook Pro, OS 10.6.8, FCP 7 & DVD SP4
    Thanks for your suggestions 😉
    Michael
    Michael Brown
    Dick Osso replied 14 years, 3 months ago 4 Members · 4 Replies
  • Roland R. kahlenberg
    June 18, 2012 at 12:33 pm
    Perhaps you’ve posted in the wrong forum?
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Michael Brown
    June 18, 2012 at 1:19 pm
    What do you know, so I have. Thanks, Roland.
    Michael Brown
  • Juan Manuel
    June 18, 2012 at 8:28 pm
    Get your Pal prores master into compressor (or maybe Adobe Media Encoder if you have it) and convert it using one of the ntsc dvd templates. Make a test with a small part of your short film (ideally, one with the most motion) and see how it ends. You’ll want to use the best options in the frame controls. YMMV, but you should be able to get satisfactory results.
  • Dick Osso
    June 27, 2012 at 8:34 pm
    Hi Mike
    I read a year ago POSTING that you had a huge issue with DVDSP4 and the crashing of IMAGE BUILD.
    I am having the same issues….I am out of ideas and who to turn to.
    Can we email or talk by phone so I can figure out what is corrupted ? I have 80 people waiting on this project.
    Dick Osso
    dickosso@mac.com
    Dick Osso
