Converting old motion math preset into expression
Hi all,
I need to use the old “spring” motion math preset in AE 6.5. Unfortunately, I’m extremely lame in understanding Java script logic. The .MM format cannot be imported in AE any more, and the text within it can’t be imported as an expression AS IT IS.
Is there any way to easily convert this text so that it can be imported as an expression ?
Sorry if the answer is obvious to you guys, but I just can’t figure it out by myself…
Thanks a lot to anyone who can help !
Just in case, here is the text content of the old .MM file :
// One spring – version 1.2
// This script attaches a spring between the 2 layers shown in the popups.
// Layer 1 keeps its original motion, while layer 2 is attached by a spring to it.// LAYER PROPERTY CHANNEL
// 1: Layer that moves doesn’t matter doesn’t matter
// 2: Layer attached to #1 by a spring doesn’t matter doesn’t matterif (time() == start_time) {
rest_length = 10; // rest length of spring in pixels
damp = 0.95; // Damping (0 = infinite friction, 1 = none)p1 = value(pop_layer(1), position);
p2 = value(pop_layer(2), position);last_p1 = tmap(time() – step_time, value(pop_layer(1), position));
last_p2 = tmap(time() – step_time, value(pop_layer(2), position));v1 = (p1 – last_p1);
v2 = (p2 – last_p2);
} else {
p1 = value(pop_layer(1), position);delta = p2 – p1;
n_delta = normalize(delta);a = 2 * n_delta * (length(delta) – rest_length) * step_time;
v2 = (v2 – a) * damp;
v1 = (v1 + a) * damp;p1 = p1 + v1;
p2 = p2 + v2;
value(pop_layer(2), position) = p2;
