Activity Forums Adobe After Effects Converting NTSC to PAL, keeps aborting
  • Converting NTSC to PAL, keeps aborting
    Posted by Brids78 on April 18, 2006 at 1:29 pm
    Hi
    I’m trying to convert a whole bunch of NTSC video files into PAL.
    I made a comp that combines the 29 fps footage(interpreted as 25 fps) and the sound of of the original footage into the Pal frame rate movie. In the render settings I stretch it to the Pal format.
    It works with one clip, then it keeps aborting with this error message: AFTER EFFECTS ERROR: COMPRESSING OF OF A FRAME OF THE CLIP: ERROR OF THE QUICKTIME CODEC (-8966).
    If I re-open the project it works again for one time.
    Where is the problem, and where the solution?
    Thanks in advance
    Flo
    Brids78 replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
