Activity Forums Apple Final Cut Pro Legacy Converting non-drop to drop frame for broadcast
  • Converting non-drop to drop frame for broadcast
    Posted by Suzan Beraza on March 4, 2011 at 4:55 am
    Hello friends in moo,
    I have a project that I need to master to HDCAM 60i for broadcast. My film was shot and edited 24p. This is about all the non-drop and drop frame stuff that I really struggle with. My final master has to be exactly 56:46.
    I have looked at other posts to try and figure out any time discrepancy that could be caused. I found a cool workaround using a slug that you create in a 59.94 project and then bring over to your project and it showed that I should adjust and make the project 56:42:13 to compensate. Is anyone out there brilliant enough to check this to make sure that is correct? I’m sure you are. You will forever be in my debt.
    Warmly,
    Suzan Beraza
    Suzan Beraza replied 15 years, 6 months ago 2 Members · 2 Replies
