Activity Forums Apple Final Cut Pro Legacy Converting MXF audio and video into FCP 7
  • Converting MXF audio and video into FCP 7
    Posted by Stephen N. on February 6, 2012 at 7:26 pm
    Hello all,
    I have a bunch of clips that need to be cut that are all on an external hard drive. The contents of the drive are:
    Audio folder:-MXF Files
    Video folder-MXF files
    Clip folder-XML files
    Icon-BMP files
    Proxy-(empty)
    Voice-(empty)
    What is the best way to import these into FCP 7? Log and Transfer doesn’t work as the files are greyed out. Also all these files have a little lock icon on the corner of them. Does that make a difference?
    Tariq Salqan replied 11 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    February 6, 2012 at 7:31 pm
    This is the workflow you need to follow…
    Tapeless Workflow for FCP 7 Tutorial
    Shane
    Little Frog Post
  • Stephen N.
    February 6, 2012 at 7:55 pm
    Thank you that is a great tutorial, but do I need to purchase a 3rd party program for these MXF files?
  • Shane Ross
    February 6, 2012 at 8:05 pm
    No. They should work just fine in Log and Transfer…if you follow the proper steps I laid out. Don’t go digging into the folders with Log and Transfer. Select the main folder that has the CONTENTS folder inside. As I said, each card should be backed up to a new folder with a unique name, and that name becomes the REEL number. Inside that folder should be CONTENTS and LASTCLIP. Just select that folder. If you don’t have that, and only have the CONTENTS folder, make a folder to but that into, and then select that.
    Shane
    Little Frog Post
  • Stephen N.
    February 6, 2012 at 10:21 pm
    Perfect. Thanks for your help.
  • Brown Maty
    February 22, 2013 at 12:48 am
    If your MXF file is Canon camcorder, I believe the post “Two ways to ingest Canon XF305 MXF recordings to Final Cut Pro 7” can give you a big help.
    Sony NEX-FS700 AVCHD to FCP
  • Kayla Wang
    July 25, 2013 at 8:31 am
    For the MXF video and audio clips, you can use a MXF convert like TransMXF, it works well for converting the format and do some simple editing. For the others, sorry I have no idea for how to deal with them.
  • Tariq Salqan
    July 25, 2015 at 12:44 pm
    Pro Video Formats 2.0.1 from apple will solve your problem no need to convert..Cheers!
