Activity Forums Adobe Premiere Pro Converting .MTS to MXF is giving 2 mono audio tracks instead of 1 stereo.
  • Converting .MTS to MXF is giving 2 mono audio tracks instead of 1 stereo.
    Posted by Stephen Pickering on September 20, 2013 at 9:51 pm
    I might be overlooking something but I don’t see any way to get a single stereo audio track with my .MXF files I have converted.
    Is there a trick to this?
    The reason I need this is that I just finished a project which i didn’t realize has a spanned MTS. file. So now when I’m exporting I get sluggish results (as in 12+ hours for 30 minutes of footage). I’ve already mixed the stereo audio track with “fill Left” and “fill Right” effects. So a simple “Replace Footage” edit (to swap the MTS with a MXF) would be ideal.
    Or should I just do a .MOV and call it a day? I like MXF, but I’m open to other options. The least compression the better.
    Stephen
    Stephen Pickering replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
