Activity Forums Apple Final Cut Pro Legacy Converting mpg to mp4
  • Converting mpg to mp4
    Posted by Digikid on November 15, 2005 at 6:51 pm
    I converted an mpg to mp4 using final cut pro- export- quicktime conversion-mp4. The video however shows up tiny on a black background. Without adding audio to the sequence this does not seem to happen. Any idea of how I can resolve this issue? Thanks for your help
    Digikid
    Tim Brickley replied 20 years, 9 months ago 4 Members · 3 Replies
  • Todd Perchert
    November 18, 2005 at 4:02 pm
    Try converting the mpeg using QuickTime Pro instead. TC
    TC Perchert
    KRQE Commercial Producer
    Albuquerque, NM
  • Daniel Serrano
    November 25, 2005 at 2:01 am
    you have to separate the audio and video streams, this is called demuxing… so try google on bbdemux, and it could work for you, or a much better solution ffmpegX…..
    and it will work… QT 7 pro doesn’t do it for me… at least on the audio part.
    Hello from Mexico….
  • Tim Brickley
    December 14, 2005 at 6:57 pm
    Thanks, Daniel – was able to demux w/ bbdemux….now, how do I import the seperate streams into FCE??? Thanks, and hola to Mexico!! Tim in Indiana…..
