Activity › Forums › Apple Final Cut Pro › Converting Mono audio to dual Final Cut X 10.4
  • Converting Mono audio to dual Final Cut X 10.4
    Posted by Jody Mitchell on March 6, 2018 at 2:53 pm
    Hi everyone
    I’m trying to convert some audio that was recorded with a lapel mic and therefore comes through in mono (just one speaker).
    I have this clip synced via multicam but can’t seem to turn it from mono to dual.
    Any tips / advice / guidance would be really appreciated!
    Thank you
    Jody Mitchell replied 8 years, 6 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    March 6, 2018 at 7:29 pm
    Mono to dual mono you mean? You’d need two channels for dual mono, but you have one channel, right?
    Jeremy
  • Brett Sherman
    March 10, 2018 at 2:31 pm
    I think what you actually have is audio that FCP X is interpreting as “Stereo” where you have lavalier in one channel and maybe silence in the other. So you need to go to the Audio inspector and change it from “stereo” to “dual mono”
    Here is where it is in the interface.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
  • Jody Mitchell
    March 11, 2018 at 4:21 pm
    Thank you
    I’m not really sure what the issue was, but I found that I couldn’t find that option to click on to dual.
    I discovered that if you double click the multicam clip in the time line and then click on the corresponding sound file, then go to inspector you can change it to the dual functionality as described by Brett.
    Thanks for the help!
