Activity › Forums › VEGAS Pro › Converting JPG’s
  • Mike Kujbida
    July 17, 2009 at 10:03 pm
    While you can use JPGs in Vegas, it seems to like PNGs better.
    I’ve been a big fan of IrfanView (it’s free) for a long time now.
    Batch conversion and batch rename tools are a small part of it’s extensive list of tools.
    edit: two (very quick) votes for IfanView so that should tell you something 🙂
  • Steve Rhoden
    Simply use an image editing software to handle that
    side of things: Corel Photo-Paint and Adobe Photoshop
    as you know are the two best…Or on the free side, the
    best option is irfanview.
    https://www.irfanview.com/
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • Ralph Hajik
    July 18, 2009 at 5:17 am
    Hi Norman,
    I use Photoshop CS2 by setting up an Action, the pixal size, PNG and let it go. It’s time for a coffee break.
    Ralph
  • Norman Willis
    July 19, 2009 at 6:25 am
    Steve, Mike, thanks.
    I got IrfanView installed and running with no problem, and converted a whole bunch of stuff in five minutes or less. Or so I thought.
    Before the alleged conversion, the .jpg’s would not go onto the timeline. Every time I tried it, I got a red O with a slash through it. However, after the alleged batch .jpg to .png conversion, the files now show up in Explorer as IrfanView files. I was able to drag them onto the timeline, and so I just assumed that they were now .png’s. However, looking at them again, they are still .jpg’s, just renamed as IrfanView .jpgs. But for some reason they consent to get dragged onto the timeline now????
    Now that the Sabbath is over, I thought I would go ahead and convert the rest of my .jpg’s to .png’s, so that it would all be done. I did the same as I did on Friday (at least I think), opening up IrfanView, and going to File >> Batch Conversion Rename. I selected all of my .jpg’s in D:MyPictures, and clicked on “Output Directory for Result Files”, which also gives me D:MyPictures. Then I clicked on “Start Batch.”
    Now all the .jpg’s in D:MyPictures are IrfanView .jpg’s. They all drag onto the timeline, but they did not convert to .png’s (either).
    I suppose as long as they drag onto the timeline I don’t have any real problem (so long as they render, which I don’t know yet); but what am I missing? How do I use IrfanView to convert the .jpg’s to .png’s?
    Norman Willis
    http://www.nazareneisrael.org
    servant@nazareneisrael.org
  • Norman Willis
    July 19, 2009 at 6:39 am
    I thought I should do a test render (halfway through the project) just to make sure these IrfanView .jpg’s are going to render (and not make my project crash).
    What means, “Save project as path reference in rendered media”?
  • Norman Willis
    July 19, 2009 at 6:51 am
    Hi Ralph.
    I also have CS2, although I only have it installed on my Vista 32 machine (laptop), because I am not sure what would happen if I installed it on my workstation (Vista 64). I suppose I could set a disk image restore point, and try loading it on Vista 64. Do you suppose the drivers would all work? Or am I just asking for trouble?
    I have not had time to learn Photoshop CS2 yet. I see a tab on the right labeled ‘actions’. Is that what you mean?
    And then what do I do?
    Norman Willis
  • Norman Willis
    July 19, 2009 at 7:44 am
    I am getting an error message on the test render at about 4% progress:
    “The system is low on memory.”
    Vista 64 Ultimate
    CoreDuo Quad Q9650 at 3.0GHz
    8GB DDR2 RAM
    4GB ReadyBoost RAM
    Paging file set to 12GB
    Target is Vimeo/YouTube HD.
    Save as type: Sony AVC
    Template: Internet 16 x 9 HD 30p
    Project Properties are:
    1920 x 1080 29.970 fps
    progressive scan
    PAR 1.0000
    29.970 fps
    Pixel format: 32-bit floating point (full range)
    Compositing gamma: 1.000 (linear)
    Rendering quality: best
    Motion blur type: Gaussian
    Deinterlace method: none
    Adjust source media to better match project or render settings is checked
    Audio:
    Master bus is stereo
    Number of stereo busses is 0
    Sample rate is 44,100
    Bit depth is 16
    Resample and stretch quality is Best.
    All four cores run at about 97%, Windows Task Manager shows physical memory usage at about 3.12 GB (while it shows 2.65GB usage at idle). Then when I go tor ender, I get to about 4% progress on the indicator, the system gives me a “low memory” error message.
    I rebooted the system, re-rendered, and still get the same error message.
    Is this likely due to the (IrfanView) .jpg’s? Or is there something wrong with my Project Properties, or Render As selections?
    Or is there some other issue?
  • Norman Willis
    July 19, 2009 at 8:30 am
    OK, I got it to render using the Main Concept AVC/AAC (.mp4) using the Apple iPod 640×480 video template.
    Why does the Sony AVC not work, and the Main Concept AVC works (with an iPod template?)? Am I losing anything by using the Main Concept AVC template? I noticed that I had letterboxing top and bottom.
    Memory usage stayed down around 3.3 GB the whole time, so I’m not sure if I need the swap file up at 12GB?
    Any help you can give me would be greatly appreciated.
  • Norman Willis
    July 19, 2009 at 8:37 am
    The Main Concept Default Template also gives a ‘low on memory’ error. So it looks like only the iPod 640×480 template works?????
    Is this the way it should be?
    And how do I get away from the letterboxing?
    Thanks.
  • Theo Van laar
    July 19, 2009 at 10:37 am
    ‘I also have CS2, although I only have it installed on my Vista 32 machine (laptop), …..
    And then what do I do?’
    So why don’t you just use Photoshop CS2 Actions for the conversion?
    In photoshop CS2:
    Open a .jpg image
    Open the ACTION palette (WINDOWS-ACTIONS)
    Click on the CREATE NEW ACTION button at the bottom of the pallette
    Give the ACTION a name and click RECORD
    Perform all the tasks you would like to do with the image (in this case only saving as .PNG in a new folder
    Click the STOP RECORDING button at the bottom of the ACTION pallette.
    You have just made your first ACTION
    To play your ACTION on a folder with images:
    FILE-AUTOMATE-BATCH
    a popup windows opens
    Select the ACTION you would like to perfom (you gave it a name!)
    Select the folder with the images you would like to change
    Select the folder you want to save the new .PNG images
    Click OK
    Time to get your well earned cup of coffee….
    Theo
Page 1 of 3
