Activity Forums Apple Final Cut Pro Legacy Converting HVX to NTSC
  • Converting HVX to NTSC
    Posted by Ben Chappell on July 18, 2006 at 5:03 pm
    We’re working on a job right now that was all shot on HVX200 (720p60). everything is great inside of FCP and even monitoring through AJA Kona2 to a component NTSC monitor. However, we need to make DV NTSC resolution quicktimes pretty regularly (every few days) of rough cuts for the client. Is there any EASY way to export out a 4:3 Quicktime that puts widescreen bars on and doesn’t distort the original aspect ratio?
    Shane Ross replied 20 years, 2 months ago 2 Members · 1 Reply
  • Shane Ross
    July 18, 2006 at 5:57 pm
    Just copy your sequence and paste it into a DV/NTSC timeline and render. Then output a Quicktime Movie (not Quicktime conversion, as you have already converted it at this point).
    It will be letterboxed.
    Shane
    Littlefrog Post
    http://www.lfhd.net
