Activity Forums Apple Final Cut Pro Legacy Converting HDV (XD Cam) to SD I get lines in footage
  • Converting HDV (XD Cam) to SD I get lines in footage
    Posted by Cathy Mayville on February 23, 2009 at 4:30 pm
    Hi! I am pulling XD cam footage off of the cards through final cut. The media was shot
    as frame size: 1920 x 1080, 29.97 frps. xdcam ex 1080i 60 compressor, field dominance Upper,
    and pixel aspec square.
    I need to convert to to SD. I tried doing an uncompressed 10 bit 720x 486 CCIR 601 NTSC (40:27)
    and the stuff gets lines in it. Pixel aspect ratio is CCIR 601 I tried playing with the field dominance, but
    “upper”. “Lower” and “:None” al had lines in it.
    How do I down convert this stuff so it doesn’t look awful? Thanks!
    Cathy Mayville replied 17 years, 2 months ago 3 Members · 5 Replies
  • Mark Maness
    February 23, 2009 at 6:15 pm
    How are you converting this footage? Deck? Software? What?
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Cathy Mayville
    February 23, 2009 at 6:29 pm
    I was trying to down convert in FCP by changing sequence settings from HDV to 10 Bitt 422.
    But, I recently read that I should not convert in FCP. I should do it through my Kona LHE card.
    So now I am trying to figure how to do that…any thoughts?
  • Cathy Mayville
    February 23, 2009 at 8:59 pm
    Does anyone know how to use KonaLHE to down convert from FCP HDV sequence to digi beta (SD)
    deck? If not, anyone know where I can get a KonaLHE manual or tutorial?
  • Rafael Amador
    February 24, 2009 at 6:53 am
    If you are converting in FC you need to make sure that your HD footage (Upper) gets the Shift-fields filter when dropped in a 8/10b/Proress SD NTSC sequence (Lower).
    I think that the AJA LH can do the downconversion without problems.
    Faster and better than in FC.
    rafael
    http://www.nagavideo.com
  • Cathy Mayville
    February 24, 2009 at 3:29 pm
    Thanks Rafael,
    I ended up calling AJA to get the low down on down converting through Kona Card.
    They were a huge help-props to the AJA peeps.
    You are right, AJA was faster and absolutely better than FCP conversion. Thanks for your help, Cat
