Activity › Forums › Adobe After Effects › converting HD video to cartoon???
  • converting HD video to cartoon???
    Posted by Boxcarfilms on May 14, 2006 at 12:32 am
    I recently went through the 3-part tutorial called “Converting Video to Cartoon.” I followed along with the steps and everything worked fine. Now I am working on a project in 720p shot with the HVX-200 (1280 x 720 pixels). I am trying to convert the video to cartoon using the same steps as the tutorial. Everything works fine until I go to batch process the image sequence in Bridge. As the images are processed by Illustrator they are resized, so my finished image sequence has been cropped down to 720×480. I think the problem is with Bridge rather than Illustrator because if I open one of the frames in Illustrator, click Live Trace, then save it again it keeps its original resolution.
    Has anyone run into this problem? Is there a setting I can change in Bridge so that it won’t resize my images as it processes them?
    Any help would be greatly appreciated. Thanks!
    Boxcarfilms replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
