Activity Forums Apple Final Cut Pro Legacy Converting from US DSLR to European final delivery
  • Converting from US DSLR to European final delivery
    Posted by Antony Tsoukatos on February 13, 2012 at 5:07 pm
    Hello all
    Sorry if this has been covered before but I would like to ask what would be the method to convert shots that were taken in the US but the edit is going to place in Europe. To explain:
    All shots were taken using 5D MkII with 23.98 fps and it is progressive. I want to convert everything to Apple Pro Res but I am not sure what frame rate to use. The producer wants to retain the 24fps filmic look.
    Should I export Pro Res in 24fps or retain the 23.98 and put all converted rushes in a 24p timeline?
    The final deliverable needs to be something that should be able to retain good conversion for both NTSC and PAL standards.
    I am on FCP 7.0.3
    Cheers all
    Antonis
    Antony Tsoukatos replied 14 years, 6 months ago 2 Members · 4 Replies
  • Shane Ross
    February 13, 2012 at 5:29 pm
    Convert to ProRes. Conform with Cinema Tools to 25fps. The footage will speed up slightly, and the audio will have a slight pitch. But, now the PAL people can edit it. And it will still look like 24fps, because 25fps is just one frame more.
    Shane
    Little Frog Post
  • Antony Tsoukatos
    February 14, 2012 at 3:13 pm
    Cheers for that Rane
    We were thinking of retaining this in the 24fps format (easier to go to 30fps as well as 25fps).
    What would someone recommend?
    Antonis
  • Shane Ross
    February 14, 2012 at 5:18 pm
    23.98 is a universal mastering format. You can convert to 29.97 and 25fps very easily.
    Shane
    Little Frog Post
  • Antony Tsoukatos
    February 15, 2012 at 2:57 am
    Superb. Cheers for the reply back and apologies for the amateurish question.
