Activity › Forums › Apple Final Cut Pro Legacy › Converting flv to QT?
  • Converting flv to QT?
    Posted by Mike Raff on April 12, 2010 at 11:47 pm
    I’ve been asked to make some minor edits to a webcast that was captured as an flv file.
    What’s the best way to convert flv to mov, so I can edit in Final Cut? Is there some freeware that I can use to convert the file? Or should I find some software that will edit the flv natively?
    Any advice would be most appreciated.
    Mike Raff
    Richmond, VA
    John Fishback replied 16 years, 5 months ago 5 Members · 4 Replies
  • Rafael Amador
    April 13, 2010 at 1:36 am
    Hi Mike,
    Download and install Perian.
    You will be able to open the Flash clips in QT, and so export.
    rafael
    http://www.nagavideo.com
    Pleas have a look to my clip:
    https://reels.creativecow.net/film/4452
    Feedback welcomed
  • Michael Craven
    April 13, 2010 at 2:47 am
    MPEG Streamclip will do it and it’s free. It’s a great app to have in your toolbox.
  • Bret Williams
    April 13, 2010 at 4:36 am
    Depending on the flv codec used, you might be able to change the .flv to .mov
  • John Fishback
    April 14, 2010 at 3:04 pm
    The problem with changing .flv to .mov IMHO is you’d then have an H.264 file which is not an edit codec. You still have to convert to ProRes or other format to edit. Don’t forget to make sure your audio sample rate is 48kHz, not 44.1kHz.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
