Activity › Forums › Apple Final Cut Pro Legacy › Converting FLV files to anything FCP can handle
Posted by Rj Thomas on November 25, 2007 at 7:25 pmAnyone know of a good/ decent and hopefully free way to do this?
Ben Scott replied 18 years, 9 months ago 3 Members · 2 Replies -
Paul Dickin
November 25, 2007 at 9:06 pmHi
https://www,perian.org/ fror the Flash player component for QuickTime
https://www.squared5.com/svideo/mpeg-streamclip-mac.html for the conversion software. -
Ben Scott
November 26, 2007 at 11:19 amsurely it aint that difficult
you should be able to open flv into quicktime native, if so then just use compressor to change file formats to uncompressed .mov
the other way is get the person making the flv to export to a quicktime format to begin with e.g. blackmagic codec may be needed if they are pc and it is free from their website, on an apple with final cut pro it should definitely be done at that stage
if using flash for video graphics go for the correct colours (not too white or saturated) and line widths of more than 2 px. also make sure your frame rates match and you are working with a square pixel sized project e.g. SD PAL is 768 by 576 when in sq pixels
