Activity Forums Adobe After Effects Converting float to hexidecimal
  • Converting float to hexidecimal
    Posted by Kevin Burke on August 6, 2012 at 12:50 am
    Hello,
    I’d like to set the source text of a Text Layer to the Hex value of a color control. The following code seems right, but the text field only reads zero. If I set the value to the var color without converting, I get a long float such as 0.86274516582489. Please help! Thank you!
    var color = thisComp.layer("ColorPicker").effect("Color Control")("Color")[0];
    color.toString(16);
    Kevin Burke replied 14 years, 1 month ago 43,645 Members · 1 Reply
  • Kevin Burke
    August 6, 2012 at 2:56 am
    I found a solution – not sure if it’s the best, but it works!
    target = thisComp.layer("Colors Screen");
    colorpicker = thisComp.layer("ColorPicker");
    sampledColor_8bpc = 255* target.sampleImage(target.fromWorld(colorpicker.position), [0.5,0.5], true, time);
    R = Math.round(sampledColor_8bpc[0]);
    G = Math.round(sampledColor_8bpc[1]);
    B = Math.round(sampledColor_8bpc[2]);
    outputString = "#" +R.toString(16) + G.toString(16) + B.toString(16);
    outputString;
