Activity › Forums › Apple Final Cut Pro Legacy › Converting FCP project from 29.97 i to 24 P
Posted by Eric Goldstein on January 5, 2006 at 10:18 pmHi,
I have an FCP 4.5 project that I need to convert from 29.97 i to 24 p. Can this be done?
What is the process?Thanks in advance for any help.
Eric
Eric Goldstein
Giraffe Film Company
Los Angeles
eric@giraffefilm.comShane Ross replied 20 years, 9 months ago 2 Members · 3 Replies -
Shane Ross
January 5, 2006 at 10:40 pmYes it can.
Download FILM EFFECTS from http://www.nattress.com.
Shane Ross
Alokut Productions
http://www.lfhd.net -
Eric Goldstein
January 6, 2006 at 2:43 amThanks Shane,
A couple of questions:
1) I’m actually doing the interlaced to progressive conversion in After Effects as the entire film has special effects and has to be rendered anyway. I was going to use Magic Bullet for this. So, my real question is simply how to convert the timeline from 29.97 i to
24 p. Can you simply change the project specs? Or do you have to create a new 24p project and copy the 29.97 timeline into it? Or do you have to go through some other conversion?2) Do you or does anyone have any opinion on the quality of the progressive frame conversion between Magic Bullet, DV film and Natress’s film effect?
Thanks again,
Eric
Eric Goldstein
Los Angeles
eric@giraffefilm.com -
Shane Ross
January 7, 2006 at 7:44 pmYOu have to use a converter, like Magic Bullet or Nattress for this. Just putting it into a timeline and rendering won’t give a desirable effect. Magic Bullet and Nattress both do a good job, and I doubt you’d be able to tell the difference between the two when you were done. The bit difference is that Nattress is $100, and Magic Bullet is $795
Shane Ross
Alokut Productions
http://www.lfhd.net
