Activity Forums Apple Final Cut Pro Legacy Converting DVCPRO HD to ProRes422 wishing to preserve separate audio
  • Converting DVCPRO HD to ProRes422 wishing to preserve separate audio
    Posted by Alex Ezorsky on March 2, 2011 at 7:18 am
    So my partner needs our captured footage which is all DVCPRO HD as ProRes422. Mpeg Streamclip was the easy answer until I realized that no matter what it would mix all the audio channels (my HVX200 always produces 4) into 1 mono or stereo file, making audio mixing using the resulting files impossible for my partner. Technically I only need one of the audio tracks but since I’m not ripping a DVD the “audio mode” selector is no help.
    Any ideas on how to achieve this?
    Andy Mees replied 15 years, 6 months ago 3 Members · 3 Replies
  • Andy Mees
    March 2, 2011 at 8:33 am
    MPEG Streamclip, like most other Quicktime based apps of the ilk, will not recognize mono audio channels. Instead it treats each channel as part of a center-panned stereo pair. Instead of using MPEG Streamclip just use FCP’s Batch Export … that should work (but as ever, try the workflow out first on few small test clips before you commit the whole job).
  • John Vonmutius
    March 2, 2011 at 2:49 pm
    FCP’s Batch Export would work, but why occupy FCP during that time? Why not just use compressor? There’s a preset for ProRes422 with audio pass-through.
    Exploring the pitfalls of the 5D workflow. The many, many pitfalls…
  • Andy Mees
    March 2, 2011 at 3:02 pm
    Good call John, the conversion w/ audio pass-through should do the trick too.
