Converting Canon t2i footage to edit in Vegas pro 9
Posted by Eric Seeram on December 14, 2010 at 2:53 ami tried to research how to do this and i coulda swore i posted this but…how can i convert the file format from the canon t2i without lose of quality to edit in vegas..cause play back is horrible…
http://www.eyekonfotography.com
http://www.myspace.com/apostlemusicBob Mane replied 14 years, 1 month ago 6 Members · 8 Replies -
Rex Brown
December 14, 2010 at 4:33 amPlayback? As in playing on the timeline?
It will be horrible if you edit the native HD files from the camera. Unless you have a monster machine. Or two!
“The emptiest boxcar always makes the most noise.”
Eric Seeram
December 14, 2010 at 6:13 amyes in the timeline.. also i saw something about mpeg streamline. but i shoot in 1080 @ 30fps… it doesnt have an option for it what do i do ?
http://www.myspace.com/apostlemusic -
Al Bergstein
December 14, 2010 at 7:14 amI use Neoscene, but let me tell you, it doesn’t solve the playback issue. It’s a problem, no matter what HD format you use. If you can’t stand it, find another NLE…unless someone has an answer to this problem. I know I haven’t found the answer yet.
Alf
Jim Greene
December 14, 2010 at 12:43 pmI used Neoscene when I edited these files in Vegas 8 and the playback was actually great. Now I don’t convert at all when using Vegas 10, and the playback is tolerable, but I still think it’s better than the time and space to convert over 100MB of files for each project.
-Jim.
Robert St-onge
December 14, 2010 at 1:14 pmI have used Epic I from DVFilm with Vegas 9 and now with Vegas 10, I just drop the footage on the timeline, no conversion or proxies and it works really well.
I even edited right off the sd card to the Vegas timeline and it worked. And also rendered from the sd card!
I really believe Vegas 10 is the way to go if you are planning on editing Canon DSLR footage.
Bob Mane
July 22, 2012 at 7:40 amhello
how did you get Epic working in Vegas 10??
does it work even though DVFilm says it is not supported?
any tricks to it??
Robert St-onge
July 22, 2012 at 3:39 pmDon’t know if Epic is supported in Vegas 10, but then you don’t need it since V10 is really optimized to handle DSLR footage.
Just drop your footage on the timeline and edit, that’s it!
Bob Mane
July 22, 2012 at 9:38 pmwell on my macpro is not very snappy (not nearly as snappy as with epic)
i will try in on my newer iMac
would love epic in 10 though…might even have to install 9 for this project
