Activity Forums Avid Media Composer CONVERTING AVID SEQUENCE TO FCP
  • CONVERTING AVID SEQUENCE TO FCP
    Posted by Paul Hartel on June 25, 2008 at 6:04 am
    I’m going to copy and paste an unanswered query posted by another user that covers the same question I have. Perhaps someone will have some answers this time:
    I’ve got a finished HDV (720p) sequence, cut in Avid Express Pro (5.7) and the guy who’s doing the color correction is going to use Color. Is there a way to export/convert the sequence to a FCP sequence other than Automatic Duck? in such a way that he can just recapture the relevant media to the converted sequence/timeline?
    Any suggestions will be welcome. Thanks.
    PH
    Paul Hartel replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jon Zanone
    June 25, 2008 at 12:02 pm
    Paul –
    I’ve seen this question alot over at the Avid Editing forum. Being a closed shop (we do everything in-house, and use Avid as our edit platform), I have no experience with FCP. Perhaps you can search the forums for the answer to this question.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Paul Hartel
    June 25, 2008 at 5:09 pm
    Thanks. I tried searching, but didn’t discover an answer…
    Could be the only way is Automatic Duck; or there may be some other work arounds I can figure out.
    I remember when I worked at an exclusive Avid shop. Ahhh. That was
    sweet.
    Thanks again.
