Activity Forums Adobe After Effects Expressions Converting Audio to Keyframes (animating scale)
  • Converting Audio to Keyframes (animating scale)
    Posted by Eric Thayer on July 13, 2009 at 5:53 pm
    using this expression:
    temp=thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”)*2;
    [temp,temp]
    How can I animate the vertical (Y) scale property only?
    thanks
    Lee Skinner replied 17 years, 1 month ago 3 Members · 3 Replies
  • Dan Ebberts
    July 13, 2009 at 6:48 pm
    Like this:
    [value[0],temp]
    Dan
  • Eric Thayer
    July 13, 2009 at 7:44 pm
  • Lee Skinner
    July 15, 2009 at 4:31 pm
    Using brackets like these:
    [X,Y,Z]
    You can control any individual dimension. I often use it for wiggling or 3D offset, EI:
    position=[0,0,index*20]
    index being the layer number in your timeline panel.
    _________________________________________________
    [Design is what you leave out.]
