Activity Forums Media 100 converting audio rate
  • converting audio rate
    Posted by Bobby Mosaedi on June 28, 2005 at 4:02 pm
    i just got done doing a live recording session into media 100 digitizing at 48000 hz, but the editor working on this project is still on 44100. how can i convert the files and still maintain it’s filenames in the bin i have placed them in?
    Floh Peters replied 21 years, 2 months ago 2 Members · 1 Reply
  • Floh Peters
    June 28, 2005 at 4:09 pm
    Probably the best way is to export all the clips separately (maybe using the “export all clips” AppleScript) and then to reimport them with 44 kHz. I think that the clip names from the bin will be used as the clip names on export (and then also on re-import). Otherwise you have to modify the AppleScript to take the clip names as the filenames for export.
