Activity › Forums › Adobe Audition › Converting .AMR files
  • Converting .AMR files
    Posted by Tim Bond on September 20, 2005 at 7:10 pm
    I’ve got some recordings from a digital dictaphone that are .AMR format. Audition doesn’t read them or interperate them. They will play in Quicktime though. Any ideas?
    Tim
    Tim Bond replied 21 years ago 3 Members · 3 Replies
  • Willie Toth
    September 20, 2005 at 8:20 pm
    Did you try to rename them? Can you record from the dictaphone to the computer, that certainly would be the easiest way … WILLIE
  • Ozpeter
    September 21, 2005 at 12:15 am
    Google turns up several converters from amr to wav – eg https://www.gromkov.com/faq/faq2004-0087.html
  • Tim Bond
    September 22, 2005 at 6:24 pm
    I’ve found that i can play the files in Quicktime and hit record in Audition and it will record in real time which seems okay. I’ll look up the converter suggested.
    Tim
