Activity Forums Apple Final Cut Pro Legacy Converting A FCP Project for DVD
  • Converting A FCP Project for DVD
    Posted by Romina Rey on March 24, 2013 at 8:29 pm
    Hi
    I just had a quick question and taking any suggestions.
    I was just given a FCP project to export and compress for DVD purposes. However, the project was cut by someone else in h264. I was thinking of converting the footage to Pro Res and replacing the h264 for a better work flow and possibly final image quality for the DVD.
    Thoughts?
    Much Appreciated.
    Romina
    Shane Ross replied 13 years, 5 months ago 2 Members · 3 Replies
  • Shane Ross
    March 24, 2013 at 9:03 pm
    Change the sequence Compressor to ProRes and render. Try that.
    (Sequence Settings: Compressor)
    Shane
    Little Frog Post
  • Romina Rey
    March 24, 2013 at 9:21 pm
    Thanks for your suggestion. I’ll try that.
    Do you think that’s better than recompressing the sequence using media manager?
  • Shane Ross
    March 24, 2013 at 11:04 pm
    This is quicker and often works. If it doesn’t, decompress with MM
    Shane
    Little Frog Post
