Activity › Forums › Adobe Illustrator › Converting a CAD file to Illustrator
  • Converting a CAD file to Illustrator
    Posted by Brian Tetamore on April 16, 2007 at 6:00 pm
    I’ve imported a .dwg (CAD) file into illustrator. All the layers show up, but I can’t see anything despite going through each layer and turning on and off visibility. I think I probably have something set wrong. Can anyone help me out?
    The Visual Rabbi
    Mike Gondek replied 19 years, 5 months ago 2 Members · 1 Reply
  • Mike Gondek
    April 17, 2007 at 1:47 pm
    Try doing a ctrl Y in illustrator to see if the paths are there in outline view. You may have a setting in CAD to change, to fix this. Also try a very simple CAD drawing to see if you can get a simple shape to convert.
