Activity › Forums › Canon DSLR Cameras › converting a 60fps 1280×720 to a slowmo 23.98fps clip
  • converting a 60fps 1280×720 to a slowmo 23.98fps clip
    Posted by Marc Horowitz on March 17, 2011 at 1:42 am
    I’m having a hard time finding info on how to convert a 7d 60fps 1280×720 to a slowmo 23.98fps clip and then importing into final cut. Do I use cinema tools to change the frame rate? What are the steps in that case? Or can I do this in FCP? Do i start with the original h.264 file or use the converted prores422? just not sure what is best or where to start. Thanks very much.
    Rafael Amador replied 15 years, 6 months ago 2 Members · 1 Reply
  • Rafael Amador
    March 17, 2011 at 8:53 am
    Hi Marc,
    You need to Conform the file in CinemaTools.
    Is just a click. No rendering involved.
    Duplicate your file before, because the operation has no way back.
    rafael
    http://www.nagavideo.com
