Activity Forums Cinematography converting a 3-ccd camera to HDR ?
  • converting a 3-ccd camera to HDR ?
    Posted by Richard Herd on February 10, 2013 at 8:17 am
    Has anyone ever heard of anyone else converting a 3-ccd camera (like the Panasonic HVX-200) to an HDR (black and white) camera?
    Angelo Lorenzo replied 13 years, 7 months ago 3 Members · 4 Replies
  • Seth Marshall
    February 11, 2013 at 2:39 am
    No, but I’m assuming you’re considering combining the luminance channels in each color to do this?
  • Richard Herd
    February 11, 2013 at 5:44 am
    [Seth Marshall] “combining the luminance channels”
    Yes!
    A black and white image would be the goal…for now.
    It would also be ideal if the gain switch was a “contrast ratio” switch. In effect, 0 gain meant capture the image as:
    CCD1: -1 EV
    CCD2: 0 EV
    CCD3: +1 EV
    +3 gain captured the image as:
    CCD1: -2 EV
    CCD2: 0 EV
    CCD: +2 EV
    And so on.
  • Seth Marshall
    February 12, 2013 at 4:27 am
    I have no idea where I may have heard this before… Or maybe it was something I contemplated on my own even. These are the things I end up staying awake all night trying to refresh my memory.
    Have you heard of anyone doing this before or was this your idea? To use the gain to set exposure brackets/differentials sounds interesting although a complete rework of it’s intended technology which may require significant tinkering.
    In the end how would you plan to recombine for HDR?
    Man, I wish I remember when I was thinking about this. Feel like it was during an HDR craze I went through a few years ago.
  • Angelo Lorenzo
    February 14, 2013 at 12:37 am
    I’ve not tried converting a camera but my general thought is the only conversion you can make is independent gain for each chip.
    You’re already generating the possibility of an HDR black and white image just from the color image. Just use after effects to seperate channels, you can run out each channel and convert to HDR in Photoshop or Photomatix Pro.
    I’ve tested it, and to be fair, unless you have large differences in the channels due to having objects in strong primary colors, you really aren’t ending up with a true HDR level of detail.
    The independent gain is the key.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
