Activity Forums DSLR Video Converting 60p footage to look like it was shot 24p natively.
  • Converting 60p footage to look like it was shot 24p natively.
    Posted by Austin Steele on January 27, 2011 at 8:25 pm
    I shot some stuff in 60p on the 7D. I wasn’t sure if I wanted the final footage to be slow-mo or to look like native 24p. Is there a way that I can my footage to look close to native 24p footage?
    Any help is appreciated.
    Ibrahim Mohammed replied 15 years, 5 months ago 4 Members · 5 Replies
  • Richard Cooper
    January 27, 2011 at 11:13 pm
    Try going through the normal conform process in Cinema Tools and get it to standard 23.98 frame rate and then speed it up to 300% in your edit suite time line…. This will allow the footage to played back at 23.98 fps by dropping frames and not playing it back a 60 fps like the original shots.
    I think you will be surprised.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Austin Steele
    January 28, 2011 at 1:11 am
    That’s what I did and it really just looks like 60p. Is there any better ways to do this or is this really my only option?
  • Rafael Amador
    January 28, 2011 at 1:39 am
    Fallow Richard advice, or you may try as well MPGStreamclip.
    rafael
    http://www.nagavideo.com
  • Richard Cooper
    January 31, 2011 at 6:37 pm
    Run me through your work flow, cause that is NOT the result we get here.
    Richard Cooper
    Anchorage, Alaska
  • Ibrahim Mohammed
    March 31, 2011 at 10:07 pm
    Hi
    Try this it’s free
    https://library.creativecow.net/articles/kramer_andrew/fps.php
    let me know the results
    Good luck
