Activity Forums Apple Final Cut Pro Legacy Converting 4:3 DV footage to 16:9
  • Converting 4:3 DV footage to 16:9
    Posted by Steve867 on October 19, 2006 at 12:04 pm
    I have filmed a wedding 1/2 in 4:3 MiniDV and 1/2 in 16:9 Mini DV, the client wants 16:9 widesceen. Can anyone tell me if there is a plug in filter for FCP 5 that converts 4:3 into 16:9 ? I am realy worried about this wedding and how I might edit it and present it to my client.
    Enzo Tedeschi replied 19 years, 11 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    October 19, 2006 at 10:49 pm
    The way I see it Steve867, you have two options:
    1 – Letterbox the entire cut. Use a 4:3 sequence, arc the 16:9 to letterbox format, and crop the 4:3 at the top and bottom with black to give it a 16:9 look
    or
    2 – Scale your 4:3 shots up until you fill a 16:9 sequence.
    Neither is ideal, but unfortunately there isn’t much you can do to really “convert”.
    Actually, s third option I sometimes use when the above two are not suitable and I need to get rid of the black bars at the sides is to place the 4:3 shot into a 16:9 sequence twice, one directly above the other. Crop the black bars out of the top layer (feather the edges a bit), and then stretch the bottom layer horizontally to fill the width of the 16:9 sequence. Blur the bottom layer, and you can create a nice look – but it’s certainly not suitable for all types of footage or cuts.
    Good luck with it!
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    Check out our latest music video – http://www.outpostpps.com/thebleed/
    Check out the Outpost PPS Video Podcast launching October 29 – http://www.outpostpps.com/podcast/
