Activity › Forums › Panasonic Cameras › Converting 30fps slo mo to stand 24p playback – Possible?
  • Converting 30fps slo mo to stand 24p playback – Possible?
    Posted by Frank Bokoski, jr. on October 13, 2012 at 6:15 pm
    Shot with 2 HVX200s in 720P/24PN. Unfortunately one of the cams was set for 30fps (720P/24PN). Big mistake!
    So, how do I convert the 30fps slo mo footage to standard 24 for proper playback. Is this possible inside of Final Cut Pro 7? Compressor?
    Please help.
    1615, The GC Media Project
    http://www.1615.tv
    Frank Bokoski, jr. replied 13 years, 11 months ago 3 Members · 3 Replies
  • Fernando Mol
    October 14, 2012 at 3:00 pm
    You can change the speed of the footage to aprox 125%
    I believe in Final Cut you select your clip and go to the menu
    >Modify >Speed
    You won’t have any audio, but you should be able to sync.
  • Eric Mccarthy
    October 14, 2012 at 6:50 pm
    Maybe this helps? This was posted elsewhere on the Cow:
    Vincent Rosati Re: Down FPS from 30fps to 24fps GRRRRR!
    by Vincent Rosati on Aug 5, 2010 at 7:41:29 pm
    Generally, using default methods to reduce framerate from 30 to 24fps will introduce an awkward cadence to your motion.
    I haven’t had to do this for some time, but I don’t recall there being a ‘correct’ way to do it in Premiere without a plugin.
    I always did this in AE with Twixtor. Instead of simply dropping frames it would redraw frames. I believe that AE now has this function in the default installation.
    I’d look through the After Effects archives. I think Andrew Kramer has an AE tutorial for changing framerates in AE, it might be searched by ‘frame rate’, of ‘ time remapping’ or something.
    https://library.creativecow.net/articles/kramer_andrew/fps/video-tutorial.ph...
    Vince
    Let us know if you come up with a solution!
    -Eric
  • Frank Bokoski, jr.
    October 14, 2012 at 9:22 pm
    This is the solution I’ve chosen. It’s not perfect but for my needs it will be fine.
    Thanks!!
    http://www.1615.tv
