Activity Forums Apple Final Cut Pro Legacy Converting 24p HD to 1080p and 29.97 ntsc
  • Converting 24p HD to 1080p and 29.97 ntsc
    Posted by Patrick Marrero on July 12, 2009 at 8:37 pm
    Hey all,
    I have finished project that was shot and edited in Final Cut Pro at 720/23.98. I need to deliver a HD-SR Cam 1080/23.98 and a Digibeta NTSC 29.97. I was hoping to bring a post house a quicktime file of the 1080/23.98 version and a NTSC 29.97 version and have them output it to the correct tape format. My question is what is the best way to up-convert to 1080/23.98 and what is the best way to down convert and change frame rates to NTSC 29.97 using FCP or another software based solution?
    Thanks in advance for you help
    Patrick
    Michael Sacci replied 17 years, 1 month ago 2 Members · 1 Reply
  • Michael Sacci
    July 12, 2009 at 9:15 pm
    The post house should be able to do the Cross-conversion and the down-conversion from your 720p file.
    The AJA Kona3 (and some of the newer ones) can do this with no problem. If adds the pulldown for the SD also.
