Activity › Forums › Apple Final Cut Pro Legacy › Converting 1920×1080 25p Prores LT to NTSC SD
John Pale replied 15 years, 11 months ago 4 Members · 15 Replies
Paul Nevison
September 27, 2010 at 3:15 amHi John
yeah the prores issues might have been an issue that I was having with my particular set up.
I’ve moved on in software versions since those issues so hopefully all is resolved now.
thanks
Macpro Dual core 3Ghz
8GB RAM
OS 10.6.4
QT 7.6.6
FCP 7.0.3
AE CS4
BMD Decklink HD Extreme 6.6
PAL Land -
Paul Nevison
September 28, 2010 at 6:25 amfurther to this discussion, I’ve tried doing the standards conversion in compressor and while the picture is clean the graphics are distorting and tearing after the conversion.
I tried the settings suggested by John and then did a second encode using all the “best” settings but am still getting the distortion on the graphics.
can anyone suggest settings that eliminate the distortion on the text?
thanks
8GB RAM
OS 10.6.4
QT 7.6.6
FCP 7.0.3
AE CS4
PAL Land -
John Pale
September 28, 2010 at 5:28 pmTry using “Better” or even “Good” instead of “Best”, for the Rate conversion or the Resize.
The Optical Flow algorithm, while creating very nice motion, when used on the Highest Quality settings can distort graphics, unfortunately. Best is not always the best choice.
Also be sure you are keeping everything progressive (set it to Progressive in Output Fields).
You can also use Cinema Tools to conform from 25fps to 23.98, then make an NTSC MPEG-2 with that. All NTSC DVD players play 24p discs and can add pulldown on the fly, for non-progressive displays.
Conforming with Cinema Tools will result in a small speed change and you may have to pitch correct your audio. The result should be visually very clean, though.
The best way to do a standards conversion is a hardware converter, unfortunately.
Paul Nevison
September 30, 2010 at 1:06 amthanks John
using the “good” settings seemed to do the trick.
In future for productions that will be shown in both PAL and NTSC lands is it better to just shoot in 24p for ultimate compatibility?
8GB RAM
OS 10.6.4
QT 7.6.6
FCP 7.0.3
AE CS4
PAL Land -
John Pale
September 30, 2010 at 3:57 am[paul nevison] “In future for productions that will be shown in both PAL and NTSC lands is it better to just shoot in 24p for ultimate compatibility?”
Yes.
