Activity Forums Apple Final Cut Pro Legacy Converting 1920×1080 25p Prores LT to NTSC SD
  • Converting 1920×1080 25p Prores LT to NTSC SD
    Posted by Paul Nevison on September 27, 2010 at 12:26 am
    Hey all
    just looking to convert my ProRes LT 1920×1080 25p clip to a format I can then turn into an NTSC SD DVD.
    I’m looking at the presets in Compressor and wondering whether to go
    10 Bit Uncompressed NTSC or DVCPRO50 NTSC Anamorphic.
    Anyone suggest the best settings to maintain quality?
    thanks
    John Pale replied 15 years, 11 months ago 4 Members · 15 Replies
  • 15 Replies
  • Shane Ross
    September 27, 2010 at 12:42 am
    Don’t compress, then compress. That’s and extra step, and an extra layer of compression. Just export a movie from FCP, self contained, and then use the DVD presets.
    Shane
  • Paul Nevison
    September 27, 2010 at 12:48 am
    Hey Shane
    when you say use the “DVD presets” do you mean the ones in Compressor or the compression controls within DVDSP?
    I’m not 100% sure where the PAL-NTSC conversion would happen as the presets generally just convert your film to MPEG2 but keep the frame rates etc of the native file…which in my case is PAL 25p
    can you clarify?
    thanks
  • Shane Ross
    September 27, 2010 at 2:13 am
    Oh, wait, PAL to NTSC…I missed that part. That’s more complex. How about making a PAL DVD? NTSC players will play them.
    Shane
  • Paul Nevison
    September 27, 2010 at 2:18 am
    hey shane
    usually I thought it was the other way round ….PAL dvd players play back NTSC fine….NTSC dvd players struggle with PAL discs??
    In the past I’ve used compressor to convert my PAL QT to NTSC then in a second step encoded the new NTSC QT to Mpeg2 for NTSC dvd creation.
    I’m all for missing out an encode if I can.
  • Shane Ross
    September 27, 2010 at 2:41 am
    Test and see.
    Shane
  • Eric Pautsch
    September 27, 2010 at 2:47 am
    Most NTSC players wont play PAL. Most PAL will play NTSC though
  • Paul Nevison
    September 27, 2010 at 2:57 am
    Hey Eric
    yes that’s been my experience in the past. I’m in PAL land so am unable to test to see if the discs I make will play on NTSC players etc…
    I guess I’ll stick with plan A ….standards convert first, then encode to mpeg2
    thanks all
    Macpro Duel core 3Ghz
    4.0G RAM
    OS 10.4.11
    QT 7.5
    FCP 6.0.4
    AE CS3 8.0.1.8
    BMD Decklink HD Extreme 6.6
    PAL Land
  • John Pale
    September 27, 2010 at 3:02 am
    Very few NTSC players play PAL. Most modern PAL equipment will handle NTSC, but not all.
    If you want to make a PAL disc (without purchasing the Nattress plug in or getting a hardware conversion)…export from your timeline as Quicktime (same as source)
    Take that into Compressor and do the standards conversion/downconversion first. Choose the NTSC preset for 8 bit uncompressed in the Advanced Format Conversions folder. You need to turn on the frame controls…change the Resize to Better (or Best..but Better is often sufficient and much faster), set Output Fields to same as source since you are progressive. Set the Rate Conversion to Better or Best. Leave the Deinterlace on Fast (if you are using Progressive footage, it won’t actually do anything if you leave it set for that).
    Take the resulting NTSC SD 8 Bit Uncompressed file and use the appropriate MPEG-2 DVD presets.
    Do not try to do the standards conversion, downconversion and MPEG encode all in one step.
    You did not state the length of your project, but many people find that creating your own preset using CBR (constant bit rate) at 7 will look better and encode much faster. If you are unhappy with the results of the presets (which are VBR–variable bit rate), you might want to try that.
    Be sure to encode your audio to AC-3.
  • Paul Nevison
    September 27, 2010 at 3:09 am
    Hi John
    Thanks for the clarification.
    I have the Nattress plugin which in the past has given brilliant results. I just wasn’t sure if the prores issues had been resolved yet. I had a few problems a year or so ago and Graeme was looking into it.
    I’ve emailed Graeme and will await to hear before using the plugin for this job.
    the Film is 16mins long so there shouldn’t be any issues fitting it on the dvd.
    thanks again all
    Macpro Dual core 3Ghz
    8GB RAM
    OS 10.6.4
    QT 7.6.6
    FCP 7.0.3
    AE CS4
    PAL Land
  • John Pale
    September 27, 2010 at 3:11 am
    Nattress should be the way to go for you then.
    I wasn’t aware there were ProRes issues. I have never had a problem.
    Good luck.
