Activity Forums Apple Final Cut Pro Legacy Converting 1080p25 to 1080i25
  • Converting 1080p25 to 1080i25
    Posted by Prerna Saigal on June 24, 2010 at 3:44 pm
    Dear All
    I am currently working on a project where the rushes have come in 1080p25 (Apple XDCAM HD422 1080p25 (50Mb/s CBR)) and I have to give a dump out on HDcam tape (AJA Kona LH: 1080i25 10bit. I have put my edit on a 1080i50 time line and as expected there is jitter in the edit(more in camera movement shots)…I have tried lowering the speed and adding shift field and exporting my edit on AJA Kona LH: 1080i25 10bit and then adding shift field or flicker filter but nothing worked…I have also tried exporting my MOV through Mpeg Stream clip to XDCAM HD 422 1080i25 no result.
    If there is anything I am missing out or any other solution please let me know as the project has to be submitted soon… Sorry for such rush but all your help will be highly appreciated.
    Thanks for your time!
    Warm regards
    Prerna Saigal
    Mark Spano replied 16 years, 3 months ago 2 Members · 1 Reply
  • Mark Spano
    June 24, 2010 at 8:10 pm
    Not sure what your issue is, but what you tried first is correct, as long as your hardware is set up correctly. If the footage you received is 1080/25p, drop it on a (same as source) 1080/25p timeline, put your video output to AJA Kona LH: 1080i25 10bit, and away you go. The KONA card will handle adding the duplicate fields. Any judder you see then should be whatever is inherent in the footage.
