Activity Forums Apple Final Cut Pro Legacy Converting 1080p24 to 1080i50 – what’s the best workflow in FCS?
  • Converting 1080p24 to 1080i50 – what’s the best workflow in FCS?
    Posted by Gareth Randall on May 27, 2011 at 2:16 pm
    I need to convert some 1080p24 footage to 1080i50. Can anyone suggest a workflow for achieving this with maximum quality within FCS? I’ve seen workflows involving AfterEffects, but I don’t have access to that.
    All suggestions (apart from “buy AfterEffects”) gratefully received 😉
    Gareth Randall replied 15 years, 3 months ago 3 Members · 3 Replies
  • Mark Spano
    May 27, 2011 at 3:47 pm
    If total running time and speed are not an issue, the cleanest way would be to conform the footage in Cinema Tools to 25fps. It will play back around 4% faster, but look as good as the original.
  • Dennis Radeke
    May 28, 2011 at 10:56 am
    I have no idea if this would work, but it’s ‘free’ and worth a try.
    Download a trial of Adobe CS5.5 and use Adobe Media Encoder to convert your footage. The trial has all of the available codecs working for 30 days.
  • Gareth Randall
    May 28, 2011 at 3:31 pm
    Thanks Dennis, but since this will be an ongoing issue I really need an FCS-only solution. I think I can use Mark’s suggestion in concert with an idea elsewhere on the Cow to use Optical Flow in Motion and then reinterlace in FCP.
