Activity Forums Apple Final Cut Pro Legacy Converting 1080i60 to ProRes422 (HQ) for PAL Delivery – Audio Issues
  • Converting 1080i60 to ProRes422 (HQ) for PAL Delivery – Audio Issues
    Posted by Michael Schmidt on February 26, 2015 at 4:31 pm
    Hi all,
    We need to deliver 26 episodes of a US show to the Middle East. I’ve been able to get the video converted well using Compressor or AME but I’m having a terrible time getting the audio specs correct. They are requesting two stereo tracks (Full Mix/M&E) embedded at 24bit/48k Big Endian. I can get FCP7 to export with the audio tracks embedded but it they always end up at 16 bit/48 little endian. Using Compressor OR AME just seems to always merge the two stereo tracks together. Any advice on how I can accomplish?
    EDITING SPECS
    DVCPRO HD 1080i60, 29.97, 16bit/48k
    DELIVERY SPECS
    Video: QuickTime Movie (*.mov)
    Compression: Apple ProRes 422 (HQ)
    Quality: Best
    Frame rate: 25 fps
    Scan Mode: Interlaced
    Aspect Ratio: 16:9 1.78
    Dimensions: 1920 x 1080
    Field Dominance: Upper Field First
    Sound:
    Format Integer (Big Endian)
    Sample rate: 48.000kHz
    Sample size: 24-bit
    Channels: 1/2ch Stereo MIX
    3/4ch Stereo M&E
    Shane Ross replied 11 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 26, 2015 at 4:38 pm
    Go into the Sequence Settings, and in the lower right of the GENERAL Tab, change the depth from 16 bit to 24bit, and the Config to Discreet.
    Shane
    Little Frog Post
