Activity › Forums › Blackmagic Design › Converting 10 Bit to DV
  • Converting 10 Bit to DV
    Posted by Sean Lander on January 15, 2006 at 10:36 pm
    Need to convert a sequence that was captured and edited using 10 BIt Uncompressed down to DV.
    I do not want the sequence as a DV movie I want to convert all the clips used in the sequence to DV.
    Using the media manager I’ve been able to get all the clips converted, only problem is that they have
    all the incorrect field dominance. Creating a custom recompression with DV set to Upper field makes
    no difference. Is there any way to successfully convert this sequence of clips to DV?
    Mactrix replied 20 years, 8 months ago 2 Members · 3 Replies
  • Mactrix
    January 15, 2006 at 11:55 pm
    For the NTSC-guys: This is only a PAL issue.
    The Mediamanager uses the normal QuickTime-Conversion
    and so the field dominance won’t switch. Only Compressor 2
    can do this.
    If you want to do Offline-Editing, try using the Sony IMX settings.
    With 30 MBit you’re close to DV but the field dominance is also
    upper field first like with uncompressed PAL. Also Photo-JPEG is
    an option, but you won’t have realtime effects than …
  • Sean Lander
    January 17, 2006 at 1:51 am
    Thanks for the tip. No I wasn’t after an offline setting. It’s a finished TV series that I would like to take away some of and edit at home into my demo reel. Just made sense to do this as DV. I’ll have a go at IMX and see what it’s like. Thanks.
  • Mactrix
    January 20, 2006 at 10:15 pm
    By the way the IMX-Setups were fixed in the FCP 5.0.2 update.
    It might be that you have to update the easy setups because
    the field dominance was set so lower field — what is wrong.
    I also figured out that only the 50 MBit setup provides realtime
    effects … not the 30 and 40 MBit IMX. Sorry for that …
