Activity › Forums › Apple Final Cut Pro Legacy › Converted 5D footage flickers in FCP
Posted by Morten Marthinsen on December 30, 2011 at 4:34 amHey all-
I really need some help on this. I bought the Canon 5D Mark II and filmed some stuff. Then converted the footage to Apple XDcam EX 1080i60 (35MB/s), 1980×1080, 29.97 fps and put it on a Apple Prores 422 HQ, Square Pixel Aspect Ratio, Field Dominance Upper, 29.97 fps sequence in FCP. The RAW or converted footage looks great in quicktime, but in Final Cut it becomes choppy and it flickers. Especially when i pan (the footage pans). Its not like its crazy bad, but your eye struggles to look at it for a long time, and the footage (the quality, crispiness) looks far from how it should be. Any suggestions or tips on this is greatly appreciated.Thanks
MortenMorten Marthinsen replied 14 years, 9 months ago 8 Members · 26 Replies -
Shane Ross
December 30, 2011 at 5:56 amYou did the wrong thing. Don’t convert to XDCAM…convert to ProRes.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Colin Mcquillan
December 30, 2011 at 6:31 am[Morten Marthinsen] “converted the footage to Apple XDcam EX 1080i60 (35MB/s)”
convert straight to prores – no reason for xdcam. If you are using FCP7 download the eos plugin from Canon and use the Log and Transfer function to capture the footage from the cards or wherever you stored the files from the cards. Within the L&T interface window you can select which flavour of ProRes you want the footage converted to.
Colin McQuillan
Vancouver, B.C. -
Morten Marthinsen
December 30, 2011 at 2:54 pmHey
Thanks for the reply.
I convert it to xdcam because Apple Prores are usually much larger in size and xdcam basically gives you the same quality but less size.
I have been working on a show for Animal planet the last year where we did exactly the same thing and it worked fine. It should work fine, there is no reason why it should flicker.. Any other suggestions?
I will try and log and transfer the footage since i do have that plugin..Thanks 🙂
David Roth weiss
December 30, 2011 at 4:51 pm[Morten Marthinsen] “I convert it to xdcam because Apple Prores are usually much larger in size and xdcam basically gives you the same quality but less size.”
They are two completely different critters Morten. XDCam may appear to your naked eyeballs to be of similar quality, but you would not say that if compared the two codecs scientifically. ProRes is a superior “hi-performance” codec. Among other things, it retains vastly more color information, and holds up much better through successive generations than XDCam, which is really a highly compressed acquisition format.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Morten Marthinsen
December 30, 2011 at 4:57 pmThat is probably true, you seem to know much more than me on this, but it doesnt answer why the footage is flickering (stuttering) in FCP.
Do you have any idea why this happens?Thanks
David Roth weiss
December 30, 2011 at 5:18 pm[Morten Marthinsen] “you seem to know much more than me on this, but it doesnt answer why the footage is flickering (stuttering) in FCP.
Do you have any idea why this happens?”Sure! Sorry I didn’t see the original question and answer earlier. Your camera shoots progressive frames, yet you have transcoded the files to various interlaced formats.
You wrote: I bought the Canon 5D Mark II and filmed some stuff. Then converted the footage to Apple XDcam EX 1080i60 (35MB/s), 1980×1080, 29.97 fps and put it on a Apple Prores 422 HQ, Square Pixel Aspect Ratio, Field Dominance Upper, 29.97 fps sequence in FCP.
David Roth Weiss
Los Angeles
Morten Marthinsen
December 30, 2011 at 5:37 pmOk. So how should i go by fixing this problem? Obviously my footage cant be changed, so what settings should I convert it to so it will look better?
Thank you so much for your help
Morten Marthinsen
December 30, 2011 at 5:42 pmOk. So how should i go by fixing this problem? Obviously my footage cant be changed, so what settings should I convert it to so it will look better?
David Roth weiss
December 30, 2011 at 5:57 pmYou need to transcode the original fmo your 5D to ProRes with “none” selected as the field dominance.
David Roth Weiss
Los Angeles
Morten Marthinsen
December 30, 2011 at 6:13 pmI did do this and it still looks bad. In the FCP sequence i change from upper (odd) or none in the field dominance and it looks bad either way.
I have tried it on 2 different macbook pro´s and both looks the same.
