Activity › Forums › Apple Final Cut Pro Legacy › Converted 5D footage flickers in FCP
  • Chris Tompkins
    December 30, 2011 at 6:17 pm
    Use the Canon plugin as suggested.
    Return to the original card media, L&T the material in. Use Prores.
    It will come in AS SHOT. Progressive.
    Drop a clip onto a new, blank Sequence and let FCP match it for you.
    Chris Tompkins
    Video Atlanta LLC
  • Morten Marthinsen
    December 30, 2011 at 6:21 pm
    I have done it like this but still looks the same.
    Starting to wonder if its my canon that messes up the footage but hard to believe.
    I shoot in 29.97 fps
  • Chris Tompkins
    December 30, 2011 at 6:26 pm
    Have you watched Shane’s “Tapeless Workflow” tutorial here on the cow?
    Chris Tompkins
    Video Atlanta LLC
  • Morten Marthinsen
    December 30, 2011 at 6:27 pm
    No i havent. you have a link for it?
  • Colin Mcquillan
    December 30, 2011 at 6:41 pm
    Where is your media stored/playing back from?
    Colin McQuillan
    Vancouver, B.C.
  • Morten Marthinsen
    December 30, 2011 at 6:42 pm
    Either locally or on a 500GB drive..
  • Shane Ross
    December 30, 2011 at 7:03 pm
    Tapeless Workflow for FCP 7 Tutorial
    The converted footage you have now is a problem. Don’t use it. Toss it. RE-TRANSFER to ProRes, or if you insist on XDCAM (still horrid idea), then use a non-interlaced option.
    Shane
    Little Frog Post
  • Colin Mcquillan
    December 30, 2011 at 7:21 pm
    Internal laptop drive? could be your issue there.. You should have your ProRes footage on an external FW800 or eSata drive.
    Colin McQuillan
    Vancouver, B.C.
  • Morten Marthinsen
    December 30, 2011 at 7:47 pm
    It might be a problem, but i have seen the issue with flickering footage when having footage on an external drive and this is not like that.
    You mainly see it when you pan..Your eye tires watching it..
  • Morten Marthinsen
    December 30, 2011 at 8:01 pm
    Thanks for the suggestion but the pan is minimal.. its not fast at all..
Page 2 of 3
