Activity Forums Apple Final Cut Pro Convert XML file of captions to .srt?
  • Jeremy Garchow
    May 1, 2018 at 9:10 pm
    Subvert from the AppStore.
  • Andreas Kiel
    May 3, 2018 at 2:04 pm
    Another possible option:
    I’ve created one new app (and added a feature to X-Title Caption Convert).
    For these betas I will use Dropbox.
    New: X-Title Caption Export
    Easy way to convert one or more Caption tracks to SRT (some more simple formats will follow).
    Just drag a project from FCP browser or project XML to the app’s window, XML to the app’s icon or open an XML via menu.
    If more than one caption track is found the app asks to select one – this will happen until either all tracks are converted or the user stops the conversion.
    The .srt files will be saved to the desktop as “original project name-[caption type].[caption lang id].srt”.
    Prefs are not yet working. Current version will work for all X-Title owners without limits, for others it will stop at 88 titles per language.
    Usage is really simple, conversion fast.
    I would appreciate some sample XMLs from you.
    https://www.dropbox.com/s/av74vzijr90a75h/XTCE.dmg?dl=0
    (X-Title Caption Convert:
    Added a new Motion Template which adds a background (similar to standard captions)
    https://www.dropbox.com/s/bn4638fncr3f7po/XTCC.dmg?dl=0)
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
